Browse Forums Building Standards; Getting It Right! Re: Frame overhang 21Jul 17, 2014 6:19 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Frame overhang 24Jul 18, 2014 3:44 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Frame overhang 26Jul 18, 2014 7:43 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Frame overhang 37Jan 27, 2022 8:08 am Crazyk Update my builder dynabolted a treated pine timber under the frame. All good now. To me it looks like they put the timber formwork out by 1 plank thickness Hi Crazyk, Not sure if you are still active in this forum but I might ask anyway. I am in a similar situation currently with overhanging frames and my builder put timber with dynabolts (45cm apart) to support the overhang. Wanted to see if everything is ok with your house since you have had the same solution applied? In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7927 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3936 This is 100% true. You can not hang anything on steel frames. very frustrating 8 9101 |
