Browse Forums Building A New House Re: Who else is building with Eden Brae? 10974Dec 07, 2014 7:36 pm Jahangir Hi Shayne, I will ask HSI why alarm system needs a dedicated phone line. Will let you know. Hi Jahangir, Dedicated phone line would be the best option if HSI offer that, as there would be no need to split/prioritise the single line...but if they don't, it's well worth spending the extra on the tech to get the single line sorted so the alarm doesn't compromise your phone line. It should give you a bit of info in the Standards mentioned above regarding where the line should be routed to first, & how to best share the resource between tasks using the most appropriate device to split HSI should know how to do... Re: Who else is building with Eden Brae? 10975Dec 08, 2014 8:36 am Shayne-Livingstone23 Hi amazingk, It's a great use of space. Personally I think you should keep the wall next to the fridge, even though the cupboard is going in right next to it. It'll make it easier to put in a pull-up cupboard and bulkhead above. What were you leaning towards? Hi Guys, We went to Oran Park EDB display homes and we found that all the garage doors are 2200mm height from the pavement / concrete floor. However, in our house drawing it is shown as 2100mm from finish floor level so it seems that the earlier EDB home design was with standard garage height of 2200mm and got changed to 2100mm later. We plan to upgrade to a normal SUV (CRV, RAV, Forrester etc) in future but not sure if 2100mm height is suitable. Can you share your view if we should go with 2100mm height or higher? And do you know what the cost for upgrade? Hi Shayne, Thanks for the recommendation. We have decided to go with the wall but the question is should we need to extend the wall further by 100mm to 1100mm. Thanks for your note about the stacker door. I did not realise that it is shorter then the rest of the doors until Jah mentioned it. I have got the same "Smart Living Essential" package but with additional "Thermal Glass" inclusion. I'll double check if that clause still exist in the print. Finger cross. Hi Jah, I believe ours is the standard design and I do not know what the angular is. Well, the higher the pitch means you will have more roof space. If you intend to use the roof for storage then I would suggest to go with it. By the way, another Livingstone display home just made its grand opening last Saturday in Willowdale Estate. We were driving to Willowdale see our plot of dirt and found EDB display homes are open for visitors. There are like 3 display home on display and the Livingstone built is much better than in Gregory Hills. Re: Who else is building with Eden Brae? 10976Dec 08, 2014 8:43 am PixiGT Canucks23 Hey PixiGT We are in the exact same position as you. I thought it was strange that they were doing roof tiles, internal walls etc before bricks as the other builds in the area looked different, but looks like there is nothing to worry about Luckily you got a site camera, I visit the site every evening and I cant see anything that looks like a camera. is the camera mounted outside or inside the home? Hi Canucks23, Brick timing is flexible, as the frame is sufficient to support the roof - just ensure that the frame is still 'straight' when the stage inspections are undertaken (due before internal linings) after the roof is completed before bricks. The Onsite Eye is on a pole that looks a bit like a lamp post that is in the front corner of my block, capturing an image of the entire block every 10mins or so. I can log in at any time & view or capture, & photos are emailed to me during the day Hi PixieGT, That is so cool. How did you get the camera install? I do not think that Onsite Eye in included in contract. Re: Who else is building with Eden Brae? 10977Dec 08, 2014 10:31 am Shayne-Livingstone23 yes, keep me posted Jahangir Hi Shayne, This is the reply I get from HSI regarding Alarm system- "The standard phone point to the Kitchen has to be with your data point in regards to the NBN which we have located in the Home Theatre. You will require this second phone point with the Alarm System if you wish to have back to base monitoring or to set it up to call your mobile if it goes off. The alarm needs that line to be able to dial to make that call. Therefore is not included. " - I think I requested for this feature. Building Livingstone23 with Eden Brae Homes Re: Who else is building with Eden Brae? 10978Dec 08, 2014 6:17 pm Hi amasingk, It is pretty sweet to see the build remotely via the camera . It appeared one day in the corner of my block, prior to the build commencing! Then, I received an email with the login details. I don't recall requesting a camera, however I have been lucky to receive this service. Re: Who else is building with Eden Brae? 10979Dec 09, 2014 7:59 pm Hi stephaniek88 and Shayne, I saw that you had a discussion about the rainwater tank. I am having an issue placing our 3000L Rainwater Tank in our home design. At the moment, the rainwater tank is located at the rear of the house against a 3.2m wall. We dislike the standard 3000L round tank and we were thinking of changing it to Slimline Tank. But Slimline design it will take up the entire wall space (approximately 2.5m) and will not have any space to place our future ducted air condition. As our home is already sitting with the minimum 900mm boundary limit, putting the tank at the site is not possible. Alternatively, is to have the tank underground. Do you know what is the cost for underground water tank and where will it be located? I am worry that if we have a leak in the tank, it would cost a lot to excavate and repair it. It could potentially destroy the house. Re: Who else is building with Eden Brae? 10980Dec 10, 2014 6:55 pm Hi amazingk, We are also having a few dramas with our water tank. We only have a 390m2 block and we can't have it at the back because that's where the air conditioning unit will go and we don't want the slimline talk to go on the side of the house as it will limit the access and we won't have anywhere to put our bins. We got a quote of $2085 for an underground tank from Eden Brae, but there were no details in regards to where it will be placed. The only thing I know about these, is you need to get them regularly checked. I understand what you mean with them having the ability to ruin the whole house being underground, which is why I am still considering just putting a slimline tank down the side. I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 22225 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223588 Thanks for your reply. I will just wait and see I guess. Trying to get some more information from our builder. 9 30235 |
