Browse Forums Heating, Cooling & Insulation Re: Air conditioning! - New house, what did you choose? 2Dec 01, 2014 10:27 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Air conditioning! - New house, what did you choose? 4Dec 01, 2014 11:35 pm Actron ESP Ultima 2 x 17kw, wanted to get the platinum but at the time they did not have 3 phase. hmmm a quick look on their site confirms that this is still the case. Re: Air conditioning! - New house, what did you choose? 7Dec 06, 2014 2:31 pm Action ESP platinum ultimate w/smartphone controls, 19.3KW $18,380 Re: Air conditioning! - New house, what did you choose? 9Dec 10, 2014 12:53 am It's hard to compare prices without knowing the details of the system. It's the options and the complexity of the install that drive up the price. We're in WA and chose a Daikin 16kW + 10kW system for ~30k. Didn't go through the builder (similar price, but fewer features and less customisation), but is being installed during the build. Re: Air conditioning! - New house, what did you choose? 10Dec 16, 2014 3:54 pm 24 sq living 18kw 3 phase 2x zones $11,000 in 2007 Re: Air conditioning! - New house, what did you choose? 11Dec 16, 2014 8:11 pm Actron Esp+ 23kw. Nothing else came close to flexibility. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Air conditioning! - New house, what did you choose? 13Dec 17, 2014 11:34 am At the time we bought $2700 dearer than a daikin which really didn't compare to what was offered with the Actron. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Air conditioning! - New house, what did you choose? 15Dec 17, 2014 7:54 pm Owner builders are hard bargainers!! Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Air conditioning! - New house, what did you choose? 16Dec 17, 2014 10:07 pm I know getting ducted aircon through the volume builders is expensive as. But do I really have much choice doing it after handover in a double storey home? I could probably ask to have provisions (ducts, outlets, etc) to be put in, but with systems such as Daikin or Actron which you can get zoned areas and so forth would the motors be compatible etc? I don't suppose the whole install can be done after hand over without provisions or ripping up the plaster for the ground floor? Re: Air conditioning! - New house, what did you choose? 17Dec 18, 2014 8:33 pm Shouldn't cost any extra to get the air conditioning done by someone else other than the builder. I was able to chose the aircon specialist and hand the aircon plans to the builder. Only costs incurred from the builder was the prewiring and any concrete plinths required for the outdoor compressor(s). If the builder won't allow other trades on site, then at the very least get the ducting installed during the build (for a two storey). That, you can get done by the builder and have the 3rd party air con guys come in post-handover to complete. You need to have the dropper ducting done for a two storey during the build as there are penetrations in the first floor concrete slab, and if you have something like floortech flooring, you may have ducting running parallel to the slab. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
