Browse Forums General Discussion Re: Slab not in the right place on the block 19Nov 14, 2008 7:50 pm slabman Quote: [To make your comparison you must look at the alternative in the same light i.e. the value of an investment of $4,000 in 50 years. ] Am not sure what you mean here, but if you assume an interest rate of 6% pa compounded monthly, $4000 turns into almost $80 000 after 50 years! So if you took th $4k now, you would have $80k in 50 years if you invested it. Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 16684 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 19988 |
