Browse Forums Building A New House 1 Nov 30, 2014 1:04 pm I knew it would only be a matter of time... Id been warned that taps are flogged all the time.... But does anyone know how I can prevent it happening again? Photo below shows what was there, and on right what's there now. Do I just get a replacement tap from bunnings or do I really need the brass looking tube bit also? Or, was that just to give soon height and room between tap fitting and the ground? Does the tap fitting piece have to be brass and a special size and will I be able to just screw it on myself? Any help appreciated! Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help! How can I prevent tap being stolen?! 2Nov 30, 2014 2:40 pm B*st*rds will steal anything. I'd be keeping it in the car from now on - but it looks like they took more than the tap. You could rig yourself up a little attachment gizmo that screws onto the bit that's left. Re: Help! How can I prevent tap being stolen?! 3Nov 30, 2014 10:59 pm you should be able to get bits from bunnings. Depending on your needs you should be able to buy a tap that attaches to the outlet that is left, without needing the riser. Re: Help! How can I prevent tap being stolen?! 4Dec 04, 2014 8:46 am Replace with poly fittings. I assume they are stealing these parts for their scrap value. Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick… 0 24241 I am building a new residential house. The structural engineer suggests drilling 60 bored piers which are no less than 600mm deep and at lest 300mm in stiff clay. If… 0 988 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2907 |
