hey guys
we're just getting a quote for decking in our alfresco,
our slab is just under the roof but we want the decking to extend out.
is a slab required underneath the extra bit of decking?
cheers
Browse Forums Outdoor Living 1 Nov 05, 2014 8:34 pm hey guys we're just getting a quote for decking in our alfresco, our slab is just under the roof but we want the decking to extend out. is a slab required underneath the extra bit of decking? cheers Re: is slab required for decking 2Nov 06, 2014 6:26 pm Simple answer is no, it's not required. But having a portion of the deck not over the slab will mean a different support structure, which in turn may impact the way you intend to install the deck over the slab, i.e the height of the beams/joists off the slab may affect the level of the deck overall Re: is slab required for decking 3Nov 22, 2014 10:56 pm No, you don't need an extra slab. I'm in a similar situation. I'll be building a deck on an undercover concrete alfresco area, which extends 3m beyond the house (onto dirt). I'm planning on laying joists on the alfresco concrete slab, and using stirrups supporting a bearer/joist system for the extension. Re: is slab required for decking 4Nov 24, 2014 7:28 am Might affect termite warranty - if this is a problem ? Re: is slab required for decking 5Nov 26, 2014 9:15 pm Re: is slab required for decking 6Nov 27, 2014 3:26 pm You can see the termite line/weep holes ... and they leave a "visual" along the wall side of the decking ... or they should ... ![]() Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13629 ![]() I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6330 ![]() Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2572 ![]() |
