Browse Forums Building Standards; Getting It Right! Re: Frame overhang 21Jul 17, 2014 6:19 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Frame overhang 24Jul 18, 2014 3:44 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Frame overhang 26Jul 18, 2014 7:43 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Frame overhang 32Nov 22, 2014 8:35 pm My frame is nearly complete and I have only 2 areas where my frame is overhanging my slab. House to garage wall - approx 20mm. External bed wall - approx 30mm Now I've been trying to find the exact clause in both the BCA and AS standards for max 10mm overhang, but I can't find it. Can anyone point me in the right direction as I don't believe in motherhood statements and would like to give my builder factual evidence. Thanks Re: Frame overhang 33Nov 23, 2014 8:42 pm 2 thirds supported is the general acceptance. I don't believe that there is anything that directly says how "bad" something can be, but I think it will fall into the 1684 interpretation (not the BCA) where it talks about supporting members. If I get bored I'll have a flick through it. As for brick overhang, yes the max is stated, but there is every chance that the footing is the right width, just the rebate is out. The builder could also reduce the cavity. I think the Cavity can go down to 20mm from memory, and they probably had originally worked on 50mm or so. Frame overhang doesn't necessarily mean the same amount of brick overhang Re: Frame overhang 34Nov 23, 2014 11:17 pm Crazyk My frame is nearly complete and I have only 2 areas where my frame is overhanging my slab. House to garage wall - approx 20mm. External bed wall - approx 30mm Now I've been trying to find the exact clause in both the BCA and AS standards for max 10mm overhang, but I can't find it. Can anyone point me in the right direction as I don't believe in motherhood statements and would like to give my builder factual evidence. The figure of 10mm is in the Victorian Guide to Standards and Tolerances. Re: Frame overhang 37Jan 27, 2022 8:08 am Crazyk Update my builder dynabolted a treated pine timber under the frame. All good now. To me it looks like they put the timber formwork out by 1 plank thickness Hi Crazyk, Not sure if you are still active in this forum but I might ask anyway. I am in a similar situation currently with overhanging frames and my builder put timber with dynabolts (45cm apart) to support the overhang. Wanted to see if everything is ok with your house since you have had the same solution applied? In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7895 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3889 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8090 |
