Browse Forums Safer Living Re: Door bell 3Nov 04, 2014 8:14 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Door bell 7Nov 06, 2014 9:15 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Door bell 17Nov 18, 2014 3:08 am trayracer I got mine wired up with Cat6 cable, so I can install an internet enabled doorphone. We can make it ring our mobile phones, or any house phone (if we install one). Mobiles will even ring even when we're not at home, so we can speak to say, couriers Cool, but couriers hardly bother to ring bells these days.i should rather not start may rant on couriers. Re: Door bell 18Nov 28, 2014 8:36 pm trayracer I got mine wired up with Cat6 cable, so I can install an internet enabled doorphone. We can make it ring our mobile phones, or any house phone (if we install one). Mobiles will even ring even when we're not at home, so we can speak to say, couriers Can you provide the brand, model & cost. Does it use VoIP or do you need a landline. Thanks. Re: Door bell 19Dec 02, 2014 12:02 pm b2o Can you provide the brand, model & cost. Does it use VoIP or do you need a landline. Thanks. There are quite a few on the market, but be warned, they aren't cheap (range between $600 to $1400). Here are some links: http://www.2n.cz/en/products/intercom-s ... tView=menu http://nesscorporation.com/ness-interco ... -131b.html http://www.mobotix.com/eng_AU/content/view/full/225139 http://www.amroad.com.tw/ http://www.advanceip.com.au/shop/index.php To make it ring any or all phones in a house, I've got a cheap computer running what is effectively a telephone exchange doing the call routing (I'm tech savvy enough to set this up myself, otherwise it would be an additional cost to get someone to do this for you). Without this, I think you can only do a peer-to-peer connection, i.e. ring a single phone. The models above do SIP/VoIP, which is a standard. There are cheaper alternatives, but I suspect they use proprietry protocols. I personally think pivot door are over the top, as you said a bit impractical having a small useless section and poor insulation. I’m pretty happy with a 920x 2040 with… 1 287 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16152 |
