Browse Forums Building A New House Re: Garage door lock after handover 4Nov 10, 2014 5:41 pm Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Garage door lock after handover 5Nov 10, 2014 6:37 pm Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Garage door lock after handover 6Nov 10, 2014 6:56 pm See if your SS will let you approach the installers and add it on. You'll want it to be keyed alike to the other external doors. Re: Garage door lock after handover 7Nov 10, 2014 9:29 pm The problem with the garage in to the house door is that they are often just plain internal honeycomb doors, rather than an entrance door. So no matter how fancy a lock you put on it, a good swift kick will knock the door in. My new home will have solid entrance door in there, as well as all the external doors keyed the same.... what's the point in having 5 different keys for same house ? Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Garage door lock after handover 8Nov 11, 2014 6:49 am bpratt The problem with the garage in to the house door is that they are often just plain internal honeycomb doors, rather than an entrance door. So no matter how fancy a lock you put on it, a good swift kick will knock the door in. My new home will have solid entrance door in there, as well as all the external doors keyed the same.... what's the point in having 5 different keys for same house ? Unless you've got a metal frame then it's just as easy to kick in a solid core door as it is a hollow core. The weak point is the striker plate screwed onto the door jamb. Easier to kick a hole through a hollow core but kicking it in takes much the same amount of effort. Having kicked in a solid door I can attest to it taking little effort lol Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. Re: Garage door lock after handover 9Nov 11, 2014 7:16 pm True, the striker plate is then the weak link in the chain. I'm thinking that the honeycomb doors bend a lot more which helps the move the lock out of the striker plate anyway. Solid core doors just feel a lot nicer anyway. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Garage door lock after handover 10Nov 11, 2014 7:45 pm Spoke with the builder and a lock is fitted to the internal garage door. Not sure of the quality of the door though, hoping it is a bit stronger than your average internal door. The problem in my area is that the thieves (mostly juveniles) will go through unlocked doors, but wont actively break in which is a good thing Dale - Building Newbie Proserpine, QLD 1 4873 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 7035 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6642 |
