Browse Forums Windows & Doors Re: Sliding door mounted into floor (no step)? 11Nov 12, 2008 5:17 am EcoClassic Hi Sliding doors require drainage so the sill must be above ground level to let water in the track drain out - otherwise it will come into your home. There are ways around this, you could have a drain right next to the door, or not have the door exposed to the weather. In either case you must set the door sill (and the drain if you use this method) into the slab. Hope this helps. Hi, Yes, I agree with you. And, that's why I make sure with my bifold doors have slight slope to provide drainage to my doors. Re: Sliding door mounted into floor (no step)? 13Apr 26, 2017 1:09 pm I assume you mean into the slab... Everything is possible, but it will be expensive. I assume bricks and plaster are in place. If you lower the door then you will need an infill of aluminium above the door on the outside. The inside is just a plastering job and new architraves. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Sliding door mounted into floor (no step)? 14Apr 26, 2017 1:21 pm ECOECO I assume you mean into the slab... Everything is possible, but it will be expensive. I assume bricks and plaster are in place. If you lower the door then you will need an infill of aluminium above the door on the outside. The inside is just a plastering job and new architraves. Ed Yes , you are right. It should have been into the slab. Ours is a hebel build and the flooring has been laid out and the door installed. Re: Sliding door mounted into floor (no step)? 15Apr 26, 2017 2:59 pm ECOECO I assume you mean into the slab... Everything is possible, but it will be expensive. I assume bricks and plaster are in place. If you lower the door then you will need an infill of aluminium above the door on the outside. The inside is just a plastering job and new architraves. Ed It was a part of variation which builder missed putting in. Re: Sliding door mounted into floor (no step)? 16Apr 27, 2017 12:13 pm Then it won't cost you anything... go ahead. It should really have a replacement door as the head height won't align with other windows and doors. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Sliding door mounted into floor (no step)? 18Apr 27, 2017 3:20 pm ECOECO Then it won't cost you anything... go ahead. It should really have a replacement door as the head height won't align with other windows and doors. Thanks ECOECO. I wouldn't have thought about the alignment but I will make sure that it is done. Re: Sliding door mounted into floor (no step)? 19Jan 04, 2019 8:40 am Interesting. My old mum lives in a place that was designed for the elderly and disabled and she has a sliding door with no step to the outside and no special drainage. The slab on the outside comes right to the door. She has lived there for about 7 or 8 years and not once has had any water issues with the door, and I've been there when there has been heavy rain. the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12677 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72694 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 17122 |
