Browse Forums Building A New House Re: Building in Port Macquarie - help with Plan 5Oct 27, 2014 8:55 pm sraj Thanks Friends, Not yet decided on the builder, finalizing the plan before deciding the builder. Any changes/ recommendations would you suggest? Looking forward to your reply Thanks sraj so you designed this plan yourself? very impressive!! Re: Building in Port Macquarie - help with Plan 7Nov 04, 2014 7:51 pm You seem to have a lot of very large windows which leads to 2 questions: 1. Which way is North as glare and summer heat can be an issue. 2. Have you had an energy rating done? You may have problems meeting the requirements. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Building in Port Macquarie - help with Plan 8Nov 04, 2014 9:18 pm I like what I think your trying to do here. May I ask if you have priced it? C ( or a U if you like ) shaped houses are not as easy to build , hence somewhat dearer than the standard box shape. Heating and cooling will also cost more. Also I don't wanna wanna be a guest and stay in Bed 4, long walk to the bathroom. Also a long walk to kitchen thru the shoppers entry. Keep at it tho, the design around an outdoor living scenario can be worth it. I wish you luck. Enjoy Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Building in Port Macquarie - help with Plan 9Nov 06, 2014 10:49 am As echo says - a courtyard shaped house has more external wall than a square or rectangle (for the same size internally) so will not only cost more (per m²) - but as bashworth mentions - will affect thermal performance as you will have more external wall area for thermal transfer to occur. I am not familiar with the climate in Port Macquarie, but it looks to be a similar latitude to Perth - so working on a temperate climate, all that glass may lead to some issues. Do you have thermal mass (floor slab, brickwork internally (not brick veneer))? Where is north? When you get an assessor, look for someone who offers 'verification using a reference building' - you might well need to use this for compliance unless you want to fork out for argon filled double glazing Small footprint in Eliza Ponds, Spearwood WA Re: Building in Port Macquarie - help with Plan 10Nov 10, 2014 10:36 pm Hi Friends, Thanks so much for your suggestions. Forget to mention, house is north to rear, Idea is to minimise the cost on the roof and utilise the money on the floor area.Attached the roof plan, which might help. Bashworth, Plannning on putting some shade sails on the rear end, hence gave some concrete structures.Hope it will minimise the heat in the summer Echo, The design includes ensuites on all bedrooms, whereby bed 2 and bed4 share the same ensuite.Hope it will reduce the walk through. Thanks so much for your suggestions friends, also planning on including a round skylight in the area between the family and kitchen, with a blind to cover during summer.Any thoughts on it? As the weather in Port is not very hot not very cold, thought the design would suit perfect, but after your suggestions, thinking on how to minimise the heat? thought about using solar guard on the sliding doors, which will minimise the heat which comes from the shade sail. Hope would turn up better. Looking forward to your thoughts. Thanks Sraj. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building in Port Macquarie - help with Plan 12Jun 24, 2015 9:11 am Hi guys - any updates on the progression of your build? Follow our build - viewtopic.php?f=31&t=77542 Re: Building in Port Macquarie - help with Plan 13Jun 24, 2015 12:33 pm Love the idea of the floor plan. Have you priced it up with a builder yet? Our Build Thread - JG king Memphis Well these guys are not looking good... I sent them a written enquiry last week and they have not yet replied. If they cannot respond to a simple… 4 10628 It is in lake macquarie area and dimensions are width 14 m and depth 8 m and the slope is 1/5 going down from the road. 1 7088 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6481 |
