Browse Forums Pools & Spas Re: Pool Suction Line 3Oct 26, 2014 9:37 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Pool Suction Line 4Oct 26, 2014 10:25 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Pool Suction Line 8Oct 26, 2014 5:17 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Pool Suction Line 10Oct 26, 2014 6:26 pm venno As I will have to disconnect all my pad plumbing to move the enclosure to rip up the paving, I may re-plumb the surface pad plumbing in 50mm also, would this be beneficial? Probably not of any benefit at all, as you'll end up with a mix of 40 and 50mm pipes and fittings, and since your pump is highly likely to have only a 40mm outlet it won't make any difference unless you do all your return pipes at 50mm ... not worth the expense if you ask me.... only do it if you have to replace the whole pipe with 50mm. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Pool Suction Line 11Oct 26, 2014 7:21 pm bpratt Probably not of any benefit at all, as you'll end up with a mix of 40 and 50mm pipes and fittings, and since your pump is highly likely to have only a 40mm outlet it won't make any difference unless you do all your return pipes at 50mm ... not worth the expense if you ask me.... only do it if you have to replace the whole pipe with 50mm. I have just checked all my equipment and they all have 50mm entry/exit by default that have been adapted down to 40mm using either tail couplings or pvc reducers. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11937 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7140 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10305 |
