Browse Forums Pools & Spas Re: Question re temporary fencing 2Oct 10, 2014 4:35 pm You might want to check with your builder. Our pool came with a temporary fence for three months but they still insisted it had a hardcover. The pool builder was going to charge approx 1k to put one on but we just used some structural pine and marine ply sheets to make our own. It was a few hundred but I'll use the pine elsewhere and have already sold on a couple of the ply sheets. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Question re temporary fencing 3Oct 10, 2014 5:47 pm Yes there is a platform system that can be put over a pool. There may be an issue of it being required immediately the shell goes in because it needs to be filled straight away to stop it popping out of the ground. Re: Question re temporary fencing 4Oct 11, 2014 3:44 pm HI guys, Thanks very much for the replies. I really like the idea of doing it ourselves with structural pine and plywood. Our pool is very small, so this should be very doable (only 4.2 X 2.6). If you're in Perth Robbie I don't suppose you still have ply sheets to sell?? Mgilla I was thinking about that - can you see an issue with filling the pool etc but then just popping the hard cover on top? Thanks very much for taking the time to respond! Maggie. Re: Question re temporary fencing 5Oct 11, 2014 3:51 pm I'd be wary of just covering a fibreglass shell - unfilled - and leaving it for weeks. I love giving my Urban Myths thread a plug (see it is still going) but ... viewtopic.php?f=1&t=62127&p=1247685#p1247685 ... you can have issues with FG shells in the ground with no water in them. Re: Question re temporary fencing 8Oct 11, 2014 8:38 pm Maggie10 Hi Mike - that is some thread! Must have a proper read! Can you see an issue with filling the pool with water and then popping lid on top? In a word, ... no ... I'd probably tip in a bottle of that chlorine stuff - the pool shop has. Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3973 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1884 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39107 |
