Browse Forums Building Standards; Getting It Right! Re: New house frame issues 4Sep 26, 2014 6:58 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: New house frame issues 6Sep 26, 2014 7:23 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: New house frame issues 8Sep 26, 2014 8:29 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: New house frame issues 20Oct 05, 2014 10:08 pm Stewie D They should just move each stud as required so that they are under each truss but they will still have to maintain the max stud spacing which looks like 600mm in your case. I don't think the wall framer looked at the roofing plan when he built the walls otherwise all the studs would line up with the trusses. Wouldn't is just be easier to put in more studs and noggins? This is 100% true. You can not hang anything on steel frames. very frustrating 8 8076 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8601 I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6475 |
