Browse Forums Building A New House 1 Sep 11, 2014 3:02 pm Colours - 12/12/13 Contracts - 4/2/14 Slab - 12/3/14 Frame - 26/3/14 Lockup - 21/5/14 My Thread viewtopic.php?f=31&t=70419 Re: Does this seem right to you? 4Sep 11, 2014 8:33 pm I'm sorry dsbuild but the display version is definitely an upgrade - we asked the same (different builder but had exact as your display pics) and the drawing matches what you got. We chose to get all basic joinery in all our pantry and wardrobe/WIR areas, and plan to get a friend to replicate the display homes re functional pantries/wardrobes to avoid the exorbitant markups the builders apply. Sorry again but (annoyingly) the builder is right --- Re: Does this seem right to you? 5Sep 16, 2014 11:15 pm From the Pantry you have provided it looks like there is a vertical rail under the shelves to me. Was there anything in the specification about this because if you look in your contract I think you will find that the specification takes precedence over the drawings - not what most people think is drawings take precedence. Contracts are unfair in this regard. Good luck dsbuild, Leonardo_23 Re: Does this seem right to you? 6Sep 17, 2014 8:30 am Leonardo_23 From the Pantry you have provided it looks like there is a vertical rail under the shelves to me. I think that in both the drawing & in what's built, that line you see under each shelf is the wooden support at the back of the shelf against the wall. It's deceptive, in the drawing it does look a lot like the nicer-looking piece at the front as per the display home. I'd be annoyed; but I don't think you can do anything about it. The vertical support would probably have been needed anyway, as it's quite a long shelf. In the end I'd be telling myself it's just a pantry, and that the door's going to be closed 99.99% of the time ... Re: Does this seem right to you? 7Sep 17, 2014 9:25 am The lighter line that you see on the drawing is for the support at the back of the shelf. If it was at the front it would be a dark line like the front edge of the shelf. What has been built in your house and what is on the drawing are the same... the only thing I would think you might be able to push is the vertical support bar that is running in front of the shelves as that isn't shown on the drawings. My build: viewtopic.php?f=31&t=68002 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5900 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17545 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10479 |
