Browse Forums General Discussion Re: Does anyone have a roof pitch higher than 30 degrees? 2Sep 06, 2014 8:21 pm Small footprint in Eliza Ponds, Spearwood WA Re: Does anyone have a roof pitch higher than 30 degrees? 4Sep 07, 2014 6:08 pm Small footprint in Eliza Ponds, Spearwood WA Re: Does anyone have a roof pitch higher than 30 degrees? 5Sep 07, 2014 9:51 pm Thank you so much! We are definitely going for a more classic homestead look than a modern exterior as we live in a rural area. I guess we just need to find the balance where the roof is high but doesn't overwhelm the rest of the house and that's why I need to see these sorts of examples to get my head around it! Thanks again. Re: Does anyone have a roof pitch higher than 30 degrees? 6Sep 08, 2014 10:37 am Tristanium This was on my wishlist, sadly - most project builders stick to standard 22° here in WA. As they do everywhere. There is no point to having a high pitched roof, except aesthetics maybe. ITs basically a waste of building time and materials. Re: Does anyone have a roof pitch higher than 30 degrees? 7Sep 08, 2014 10:54 am If like Tristanium you lived in an older suburb, then the council may make you have a roof pitch to match neighbouring properties. Two local councils here have that policy. The upside also is that if the footprint of your house is relatively big then you will end up with a largish area inside the roof space. Ideal for an attic, storage or a home office etc. Dormer windows to these would also add to the overall appeal of some of those shown above. You would of course have to have strengthened ceiling joists and possible council approval to allow for this. Just something else to consider. Stewie Re: Does anyone have a roof pitch higher than 30 degrees? 8Sep 08, 2014 1:03 pm qebtel Tristanium This was on my wishlist, sadly - most project builders stick to standard 22° here in WA. As they do everywhere. There is no point to having a high pitched roof, except aesthetics maybe. ITs basically a waste of building time and materials. I am fully aware that it costs more and there is an element of wasted space but I look the look of it and we live in outback NSW with neighbours many acres away so it shouldn't bother anyone else what we do with our home. Re: Does anyone have a roof pitch higher than 30 degrees? 9Sep 09, 2014 1:01 am It sounds like you could be reliant on harvested water for potable use. Just be aware that steep rooves are also subject to roof slope factoring that allows for wind driven rain when determining gutter cross sectional areas and downpipe sizes. For example, a 30 degree slope is subject to a roof area multiplier of 1.29 and a 40 degree slope has a multiplier of 1.42. If this isn't correctly done, then you could have gutter overflow problems that result in lost yield during wind driven heavy rain events. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Does anyone have a roof pitch higher than 30 degrees? 10Oct 10, 2014 11:01 am Just beware that the current timber framing code only goes up to 34 degrees, after which it has to be engineered, so there will be quite a cost difference. Generally the 2 reasons people choose to go over is the following. 1) they are after a certain look in terms of what the house will look like and b) more storage space. If it is for the later, you will need a note on the plans as many truss bottom chords are only designed to hold the ceiling lining and not a pile of gear that you may intend to place inside the roof space. Why don't you call and talk with someone at the town planning in your council? 1 2310 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47861 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4588 |
