Browse Forums Building A New House Re: Things you forget - summary page 32 805Jul 23, 2014 7:57 pm Crazyk What do you mean by that Emz? Knew I didnt explain it very well sorry CrazyK. I mean in terms of how they join the stone to give the 40mm look. Here is a link to a picture that might explain it better, but perhaps someone with more knowledge on this subject would be kind enough to give some more info? http://vic-stonenglass.com.au/wp-conten ... iles-1.png Re: Things you forget - summary page 32 806Jul 23, 2014 8:00 pm I asked about this today and was told MV do this as standard. Re: Things you forget - summary page 32 809Jul 25, 2014 2:27 pm Wow have spent the last few days reading through the entire thread! Well done everyone who has contributed so far. I thought I had a fairly comprehensive list - boy was I wrong! We are only approaching pre-start but the one thing I have had suggested to me - that I haven't seen on here so far - is to make sure that if you have boosted HWS, make sure the booster button is inside the house. If it's outside you coould have a chilly/wet trip to put it on! Re: Things you forget - summary page 32 810Jul 25, 2014 11:35 pm I built with redink ink .im sure its a automatic booster . But I upgraded to gas boosted . I did ring the company and they did say it was . So im guessing its not like the old days when you had to turn it off and on . But you got me thinking .I might just call them again . Re: Things you forget - summary page 32 811Jul 26, 2014 9:54 am nikkis2000 We are only approaching pre-start but the one thing I have had suggested to me - that I haven't seen on here so far - is to make sure that if you have boosted HWS, make sure the booster button is inside the house. If it's outside you coould have a chilly/wet trip to put it on! On a similar topic, if you have electric boosted Solar Hot Water, particulary the more efficient Evacuated Tube type, then consider a 24hr/7day timer in your circuit breaker box. That way you can automatically set up the times and days when you want the water to be electrically boosted. In our old place, and it will happen in my new build, we had ET SHW, and set the timer to electrically boost at around 4pm every second day for an hour. If the water was at full temperature in the tank, it used no electricity, but if they days were overcast or a lot of hot water was being used, then it would boost it then. We also had the timer set to boost for an hour at around 6am on our big washing days, so we had plenty of hot water. Of course you will still get several days of no decent heating sun, but these timers also allow you to turn things on manually, you just had to remember to turn it back to timer mode afterwards. Another good reason to have your circuit breaker board mounted inside the garage behind your meter box that has to be on the outside wall. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Things you forget - summary page 32 812Jul 26, 2014 3:15 pm What's this? You have to manually turn on the booster? Ours is fully automatic gas boosted, if it's not hot enough then The gas kicks in itself Sent from my iPhone using ones and zeros and 4G Re: Things you forget - summary page 32 813Jul 26, 2014 5:46 pm hitman What's this? You have to manually turn on the booster? Ours is fully automatic gas boosted, if it's not hot enough then The gas kicks in itself Gas boosting is different, as it only boosts the hot water if the water drops below the set temperature, but with electric boosted SHW, as the water mixes it can start the boost process, even though there is plenty of sun. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Things you forget - summary page 32 814Aug 02, 2014 2:16 pm It's not so much we forgot - we didn't know anything about tile mitring and the interior designer we met with to help make selections (service offered by builder) didn't mention it, tile shop didn't mention it, pre-start girl didn't mention it and now we are almost finished build and seen our tiles aren't mitred and have horrible terracotta coloured edge!! This goes around nib wall in ensuite and is very noticeble! If we had been told this was something we had to specifically ask for we would have! Make sure you specify this!! Haven't asked our builder bout it yet but we are very disappointed it wasn't discussed as optional , they knew we were first time builders. Re: Things you forget - summary page 32 816Aug 03, 2014 6:56 am Could you go for a steel strip/edging instead or would it be too late? It is mentioned here viewtopic.php?f=21&t=42501&p=648062&hilit=steel+mitre+tile#p648062 and here is a picture with some steel edging http://blog.hgtvremodels.com/2012/09/17 ... etal-trim/ I didn't know about mitre tiles either until I found this forum Re: Things you forget - summary page 32 818Aug 05, 2014 12:26 pm First post! This is an awesome list and will be very useful in the coming months. We are about to start building and I had a thought...do you think it would be wise to install the freestanding wood heater before the ceiling and colourbond roof goes on? Thanks Re: Things you forget - summary page 32 819Aug 12, 2014 4:15 pm Gas line to the alfresco, in case you want to use the main gas line for your BBQ or outdoor kitchen. Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11779 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8515 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6749 |
