Browse Forums Building A New House Re: Stockland Elara at Marsden Park 134Jul 07, 2014 4:19 pm @AlDob: You have to be ready with your A$10K (inclusive of the initial A$1K deposit). 10% is only required if you will pay by the deposit bond or bank guarantee. I think that the A$1K initial deposit is refundable should you choose not to proceed.
The Melaleuca Land Release is on the 19th of July 2014. Registrations Open 8:00pm Sunday 13th July Release Plan: http://elara.ondicomdigital.com/upload/ ... _FINAL.pdf Price List: http://elara.ondicomdigital.com/upload/ ... _FINAL.pdf Master Plan: http://elara.ondicomdigital.com/upload/Masterplan.pdf 4-Step Land Release Process: http://elara.ondicomdigital.com/upload/ ... elease.pdf Re: Stockland Elara at Marsden Park 136Jul 07, 2014 5:36 pm Elara historical price:
1. 480sqm 06 Sept 2014 | A$384K 12 Oct 2014 | A$391K +A$7K 22 Nov 2014 | A$401K +A$10K 2. 450sqm 31 May 2014 | A$355K 28 June 2014 | A$360K +A$5K 19 July 2014 | A$362K +A$2K 06 Sept 2014 | A$368K +A$6K 22 Nov 2014 | A$385K +A$17K 3. 375sqm 31 May 2014 | A$309K 28 June 2014 | A$314K +A$5K 19 July 2014 | A$319K +A$5K 06 Sept 2014 | A$324K +A$5K 12 Oct 2014 | A$331K +A$7K 22 Nov 2014 | A$341K +A$10K 4. 300sqm 31 May 2014 | A$270K 28 June 2014 | A$275K +A$5K 19 July 2014 | A$279K +A$4K 06 Sept 2014 | A$282K +A$3K 12 Oct 2014 | A$289K +A$7K 22 Nov 2014 | A$299K +A$10K 5. 467.5 Cnr 06 Sept 2014 | A$349K 12 Oct 2014 | A$362K +A$13K 22 Nov 2014 | A$372K +A$10K Elara is indeed a very wise investment since after 3 to 4 releases the price increases could pay for your A$10K deposit. Re: Stockland Elara at Marsden Park 137Jul 07, 2014 6:16 pm kaycee Elara historical price: 1. 450sqm block 31 May 2014 | A$355K 28 June 2014 | A$360K +A$5K 19 July 2014 | A$362K +A$2K 2. 375sqm 31 May 2014 | A$289K 28 June 2014 | A$314K +A$25K 19 July 2014 | A$319K +A$5K 3. 300sqm 31 May 2014 | A$270K 28 June 2014 | A$275K +A$5K 19 July 2014 | A$279K +A$4K Elara is indeed a very wise investment since after 3 to 4 releases the price increases could pay for your A$10K deposit. Thanks kaycee. This is in fact a very useful analysis. Re: Stockland Elara at Marsden Park 138Jul 07, 2014 6:50 pm The corner blocks looks ok. What's with corner lots? Will it cost more to build? I've seen the corner lot houses in Greenway. They have fencing on the longest part of the street and the entrance door and garage on the other side of the street. Will Stockland go with this or will they require 2 facades? Re: Stockland Elara at Marsden Park 139Jul 07, 2014 9:55 pm @theziplocks: There is nothing wrong with corner lots. You just might be restricted to build structures because of the side setback that may be required. Refer to below:
http://stockland.com.au/residential/ima ... _FINAL.pdf The advantage of corner blocks is you can have an alternate garage at the rear of the house. Refer to this link for ideas: http://www.landcom.nsw.gov.au/downloads ... elines.pdf Re: Stockland Elara at Marsden Park 140Jul 07, 2014 10:52 pm Hi, bit of a novice here, but when the plan say's 450sqm block (15m x 30m) is that measured form the street or from the nature strip (council boundry) and in turn is your 3.5/4.5/5.5 m set backs meausred from the street or from the council boundry? Thanks in advanced, Matthew... |
