Browse Forums Kitchen Corner Re: upgrade cost from velour to gloss finish 2Jul 07, 2014 9:09 am Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: upgrade cost from velour to gloss finish 4Jul 07, 2014 10:55 am Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: upgrade cost from velour to gloss finish 5Jul 07, 2014 2:16 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: upgrade cost from velour to gloss finish 7Jul 07, 2014 3:12 pm Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: upgrade cost from velour to gloss finish 8Jul 07, 2014 3:28 pm iman Is it possible to change cabinet doors to drawers after the handover? If so, what is the cost of replacing the door by drawers? The dimension of each cabinet is 810 wide, 600 deep, and 900 high. Can definitely be done (happens to alot of older kitchens). It will cost you a fair bit more to do it that way though* * (in comparison to a cabinet makers price, to do it from the start, not a building variation). The cabinet maker will need to purchase a sheet of board ($110), roll of edgetape ($45ish for 25m), 2-3 hours to manufacture everything in the factory, and then charge a few hours labour to go to your place & fit them up. If it's done from the start, the board & edge is included in the whole kitchen cutlist, and the carcass' will be drilled on the CnC machine ready for drawers, so the site labour is forfeited. (they won't have to take a dawer jig to site, and manually fit the runner positions. However, if there's a massive markup on the variation from the builder to make the changes, it may not be a heap different to do this. Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: upgrade cost from velour to gloss finish 9Jul 07, 2014 5:49 pm GBDesign CuttingEdgeKitchens I assume the OP is building with a large volume builder?? If so GB Designs your estimates are way off! Extras with house and land packages are usually 3-4 times what it should cost! Absolutely mate, there's a different set of prices, and answers, with every possible scenario here . However, the OP is asking how much did you pay? From my experience on dealing with alot of different joiner firms, that's the going rates that i've seen/had clients pay. Yep, your dealing with joinery firms which is totally different. Large volume builders like the OP is using put large mark ups on everything! To give you an example, a friend of mine was building with M#@$%&#$*& and wanted to upgrade from laminate benchtops to 40mm caesarstone. The upgrade cost was $5890. I got a price from my stone mason and the real cost was $3120!!! and that doesn't take into account the cost of the laminate tops. They were paying around $3000 to much! Yes I understand there will be different prices but there is no need to get the OPs hopes up. She is building with a large volume builder and they normally sting for the upgrades! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: upgrade cost from velour to gloss finish 10Jul 07, 2014 5:54 pm iman [CuttingEdgeKitchens, is it possible to change cabinet doors to drawers after the handover? If so, what is the cost of replacing the door by drawers? The dimension of each cabinet is 810 wide, 600 deep, and 900 high. It is a common and/or acceptable practice to ask the cabinet makers of my house to install drawers and then charge me the extra cost? I am a bit concerned that the cabinet makers might charge me at builder rate. Thanks Yes it is possible but might be hard trying to find someone to do such a small job. Remember that the cabinet maker is working for the builder. The builder pays them. Normally they will put a mark up on it for the builder. Very occasionally the builder will allow you to deal directly with the cabinet maker and you wont be charged the high mark ups. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: upgrade cost from velour to gloss finish 11Jul 07, 2014 7:16 pm Thank you both CuttingEdgeKitchens and GBDesign for your valuable insights! I highly appreciate this. CuttingEdgeKitchens, the first thing I would do after handover is building WIR fitout. I need to hire cabinet makers for this job. Would these cabinet makers consider replacing the cabinet doors by drawers as a small job? The job effectively will be WIR fit out and cabinet door replacement. The WIR will be fitted on 3 and 1/2 walls. Total wall dimension size being 6m. Thanks Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7584 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18494 4 15893 |
