Browse Forums Building A New House Re: Is this normal - Designing a kitchen with builders? 12Jun 27, 2014 5:09 pm Thanks for all the replies. Looks like I will be visiting the cabinet makers but do the design myself since they will charge for drawing the plans up. I guess that's the "cons" of building with a volume builder. Hi Stefcep Thank you so much for your advice. We normally allow for 54 bricks per square meter but somehow by the time we add all the sand, cement, lintels and labour… 119 169125 Legend, it does. I figured it will be hard to get quotes anyway since it's not for an actual job but a comparison. Thanks 15 20128 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 7943 |
