Browse Forums Kitchen Corner Re: Venting Kitchen Extractor 2Jun 16, 2014 3:33 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Venting Kitchen Extractor 4Jun 17, 2014 7:34 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Venting Kitchen Extractor 6Jun 18, 2014 2:58 pm You are allowed to have flues, chimneys and pipes as long as the external wall is no closer than 900mm from the boundary ( according to the BCA now NCC ) Also ductwork used for the transfer of products coming from a heat source that contains a flame must comply with the fire hazard properties set out in AS 4254 ( but I don't have a copy of that one ). Then there may be some LGA's ( councils ) that have their own regs too but you can usually check those on their websites. Also it depends where you put the vent and what is opposite on your neighbours wall. You wouldn't want to put it directly opposite a main window that they usually leave open or if you can't put it anywhere else at least direct the vent either up or down by means of a baffle or 90º bend. Stewie No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 7112 2 5566 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7782 |
