Browse Forums Kitchen Corner Re: Joins in stone benchtops 5May 30, 2014 8:19 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Joins in stone benchtops 8May 30, 2014 9:44 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Joins in stone benchtops 11May 31, 2014 9:22 am Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Joins in stone benchtops 13May 31, 2014 9:32 am Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Joins in stone benchtops 14Jun 01, 2014 8:41 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Joins in stone benchtops 16Jun 05, 2014 1:30 pm for those with waterfall edges, does the stone completely butt up against the melamine cabinets on both sides? One side (where the pot drawers are) has a small gap, we can actually see light coming in from the other side. It seems they cut the benchtop a few mm too long and then the edge was epoxied on without due consideration. Re: Joins in stone benchtops 17Jun 05, 2014 6:22 pm Marmalade for those with waterfall edges, does the stone completely butt up against the melamine cabinets on both sides? One side (where the pot drawers are) has a small gap, we can actually see light coming in from the other side. It seems they cut the benchtop a few mm too long and then the edge was epoxied on without due consideration. Yes it should but hard up but sometimes it doesn't. It is very hard to get a mitred waterfall spot on. 1-2mm gap is acceptable against a cabinet as long as they fill with a matching silicon so you don't see the gap/light. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Joins in stone benchtops 20Dec 12, 2020 10:38 pm Correct installation of stone requires a joint at every change of direction. A U shaped kitchen will have a minimum of two joints. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7646 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6796 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5709 |
