Browse Forums Kitchen Corner Re: Joins in stone benchtops 5May 30, 2014 8:19 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Joins in stone benchtops 8May 30, 2014 9:44 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Joins in stone benchtops 11May 31, 2014 9:22 am We had caesterstone counter tops installed where I work 4 years ago (light coloured bench, i think its Ice Snow) and the joins have become more visible over the years, it's looking yellow compared to the rest of the benchtop. Especially the join along the edge to make the 40mm bench top - one of the reasons why I decided on a 20mm benchtop for home. I think it also depends on the skill of the installer. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Joins in stone benchtops 12May 31, 2014 9:27 am HomeAngels We had caesterstone counter tops installed where I work 4 years ago (light coloured bench, i think its Ice Snow) and the joins have become more visible over the years, it's looking yellow compared to the rest of the benchtop. Especially the join along the edge to make the 40mm bench top - one of the reasons why I decided on a 20mm benchtop for home. I think it also depends on the skill of the installer. You won't see the join on the edge if they are mitre joins. Re: Joins in stone benchtops 13May 31, 2014 9:32 am JB1 HomeAngels We had caesterstone counter tops installed where I work 4 years ago (light coloured bench, i think its Ice Snow) and the joins have become more visible over the years, it's looking yellow compared to the rest of the benchtop. Especially the join along the edge to make the 40mm bench top - one of the reasons why I decided on a 20mm benchtop for home. I think it also depends on the skill of the installer. You won't see the join on the edge if they are mitre joins. Yes, very true! Obviously these weren't. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Joins in stone benchtops 14Jun 01, 2014 8:41 am There are some real cowboys in the stone industry. I will only supply stone through my stone mason who I have used for years and does a good job. Occasionally I loose a kitchen because my stone is around $500 more expensive than the cheap and nasty boys. I would prefer to pay $500 more and know that the stone will last the lifetime of the kitchen, have perfect joins and my customers will be happy with it! I have heard some really bad stories about what some of the stone companies will do! Buyer beware! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Joins in stone benchtops 15Jun 04, 2014 9:05 pm If joins are a concern I would look into acrylic benchtops. You can do all the same things as with a stone (and more) but the joins are completely invisible. I have an acrylic top at my work which apparently is too long not to have a join and I have spent plenty of time looking for the join but I can't for the life of me tell where it is. Acrylic can scratch much more easily than stone though but we just buff ours back with some jiff and it comes up like new. I've had stone at home in the last and now have a laminate top but I prefer the acrylic that we have at work. It is a nice balance between feeling solid and sturdy but not too cold or hard. I used to smash too many glasses on our stone top Re: Joins in stone benchtops 16Jun 05, 2014 1:30 pm for those with waterfall edges, does the stone completely butt up against the melamine cabinets on both sides? One side (where the pot drawers are) has a small gap, we can actually see light coming in from the other side. It seems they cut the benchtop a few mm too long and then the edge was epoxied on without due consideration. Re: Joins in stone benchtops 17Jun 05, 2014 6:22 pm Marmalade for those with waterfall edges, does the stone completely butt up against the melamine cabinets on both sides? One side (where the pot drawers are) has a small gap, we can actually see light coming in from the other side. It seems they cut the benchtop a few mm too long and then the edge was epoxied on without due consideration. Yes it should but hard up but sometimes it doesn't. It is very hard to get a mitred waterfall spot on. 1-2mm gap is acceptable against a cabinet as long as they fill with a matching silicon so you don't see the gap/light. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Joins in stone benchtops 20Dec 12, 2020 10:38 pm Correct installation of stone requires a joint at every change of direction. A U shaped kitchen will have a minimum of two joints. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7507 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6712 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5652 |
