Browse Forums Building A New House Re: Things you forget - summary page 32 762May 13, 2014 11:53 am http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Things you forget - summary page 32 769May 25, 2014 9:47 am We had our Tender appointment a few days ago and there where some things I was disappointed that they couldnt help us with on our build. 1- Our slab needs the block to be leveled. They are only willing to level the foot print of the slab and no more. I asked if we could pay extra to have the block leveled right to the boundary and they said they couldnt do it. This means ill need to hire a bobcat once the house is done and do it my self (no biggie). 2- Had to pay an extra $450 to have an 86mm step down to the garage. Lucky for this forum it prompted me to ask about this. When I looked at the tender document it said level slab to garage, even though the front of my slab will be slightly raised due to the fall. 3-Asked about an upgraded anticon sarking for the color bond roof ant they said they dont offer any upgrade sarking. Just the standard one for $2.5k. I will be confirming this with them as I am not sure I believe this.... 4-We liked the 750mm push pull front entrance door handle on display at WL, but this is not available for selection. They have a slightly similar one which is thin and round (not square like displayed) which is $573. Im not too keen on paying this much for something im not 100% liking. We are going to doors plus today to price up a front door and are thinking of getting the standard included one, then changing later on with the handle we are happy with. 4- They are telling me they cannot put a cavity door to the butlers/kitchen doorway. Only willing to do a hinged door... Would really like a sliding door here and will be confirming this with them.... 5- Was told they cannot put the washing machine taps in the cupdoard. I wanted them hidden as they look quite ugly exposed. The best they can do is locate them at under bench height. But im worried they will stick out too far and not let the machine sit all the way under the bench... Not possible due to some standards which I will again be confirming... 6- Have seen some Amalfi's built with really ugly front down pipes on the front facade. I asked if this could be excluded and drained to the lower section of the roof but was told "No". Was assured down pipe will be tucked nicely as per drawing.... 7-Was told Hot water service cannot be recessed into wall. 8- Was told the fuse box cannot be put in the garage, although it was mentioned in a thread on here that it can be done (might be state specific)...? 9- Wanted them to leave off a kitchen cupboard as i will be fitting a sliding bin myself (not wanting to pay them ~$500 to do it) but am told they are unable to leave one off and must handover a "complete" build. This is weird as they are leaving our skirting boards off for us to do timber floor boards...? 10- Was told manhole cant be put in garage. Will be asking this question again. 11- Was told range hood height is 907mm from floor. Didnt click at the time but wrote it down. Will be double checking... 12- Was told tiles in wet spaced are not sealed and they do not offer this as an option. They are the things I will be discussing with them before the contract appointment. Anyone have any experience an any of these I would appreciate your input. Thanks Re: Things you forget - summary page 32 770May 25, 2014 10:13 am Amalfi_536 5- Was told they cannot put the washing machine taps in the cupdoard. I wanted them hidden as they look quite ugly exposed. The best they can do is locate them at under bench height. But im worried they will stick out too far and not let the machine sit all the way under the bench... Not possible due to some standards which I will again be confirming... If your washing machines taps are behind your machine it would make it very difficult to turn the taps off in a hurry. We have a front loader under the bench and the taps are located in the cupboard next to it, which was very handy as the washing machine connection wasn't connected properly at installation and we needed to turn it off as it was flooding the laundry, the front loader was half filled with water and there was no way i could of moved it. Re: Things you forget - summary page 32 771May 25, 2014 12:27 pm Rachi Amalfi_536 5- Was told they cannot put the washing machine taps in the cupdoard. I wanted them hidden as they look quite ugly exposed. The best they can do is locate them at under bench height. But im worried they will stick out too far and not let the machine sit all the way under the bench... Not possible due to some standards which I will again be confirming... If your washing machines taps are behind your machine it would make it very difficult to turn the taps off in a hurry. We have a front loader under the bench and the taps are located in the cupboard next to it, which was very handy as the washing machine connection wasn't connected properly at installation and we needed to turn it off as it was flooding the laundry, the front loader was half filled with water and there was no way i could of moved it. That's how we want it! Is your house an Amalfi? Are you in Victoria? Re: Things you forget - summary page 32 772May 25, 2014 6:21 pm Amalfi_536 8- Was told the fuse box cannot be put in the garage, although it was mentioned in a thread on here that it can be done (might be state specific)...? I'm guessing here, but I take it that you wanted it all in the garage ? You need to have the main breakers and of course the meters on the outside wall, but you can then go from there to put a circuit breaker 'box' on the inside of the garage. This is what we are doing, meter box on outside wall, all the breakers after that on the inside wall. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Things you forget - summary page 32 773May 25, 2014 6:27 pm bpratt Amalfi_536 8- Was told the fuse box cannot be put in the garage, although it was mentioned in a thread on here that it can be done (might be state specific)...? I'm guessing here, but I take it that you wanted it all in the garage ? You need to have the main breakers and of course the meters on the outside wall, but you can then go from there to put a circuit breaker 'box' on the inside of the garage. This is what we are doing, meter box on outside wall, all the breakers after that on the inside wall. Are you building in VIC? Did this cost extra? Thanks in advance. Re: Things you forget - summary page 32 774May 25, 2014 8:14 pm Sorry, I thought my .signature would show I was owner building in Qld. Yes, it is a tiny bit more expensive, as you have a separate circuit breaker board, but the cost of that board isn't much. Sadly though these project builders will charge you a hell of a lot more than the actual costs involved. But to get back on topic with this particular thread, separate the circuit breaker board from the meter box by putting it in to the garage space. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Things you forget - summary page 32 775May 26, 2014 11:26 am Hi Guys, First time home builder here, loving some of the suggestions. Not sure if this has already been covered but I wanted to see if anyone has any suggestions in regard to enclosing theatre rooms. The design I am currently working with had the theatre room open with only 3 walls (not really a theatre...) I am looking at putting 2 small "nib" walls on the 4th wall (facing into the hall way), which will allow for a recess for 2 large frosted glass sliding doors to sit in. My idea here was that it becomes a useable theatre, as well as a potential 4th bedroom. Has anyone tried to make a "multi purpose room " like this ? Also - Does anyone have anything positive to say about WA housing centre ? currently shopping around and I really like the package they have put together for me and the customer service so far...... But I have read some horror stories. Re: Things you forget - summary page 32 776May 26, 2014 10:29 pm Are you talking about wanting a theatre with double doors? Instead of an open one? Re: Things you forget - summary page 32 777May 27, 2014 11:56 am I am building the ivy 4 with new living homes and have replaced the large open wall with a double cavity slider. A theatre room isn't a theatre room unless it can be blocked off Re: Things you forget - summary page 32 778May 27, 2014 12:10 pm The Ebs I am building the ivy 4 with new living homes and have replaced the large open wall with a double cavity slider. A theatre room isn't a theatre room unless it can be blocked off We are doing the same. The room can also be a guest room if it has the ability to be closed off. We also added cavity doors to other areas of the house for heating and cooling efficiency. An open plan is nice but not always practical. Villina Grande Handover 10/9 Re: Things you forget - summary page 32 779May 27, 2014 12:17 pm Not sure if this has been mentioned but one of the things we arranged for was double shelf and rail in the WIR. We had it in a previous house and it was great. So hubby can have the row at the bottom, wife can have the top and with this new house we have 3 walls that have shelving so we left the shortest wall with one rail for dresses and suits etc Another thing we did was put insulation in the garage roof. If you use your garage to tinker or have gym equipment etc in it then it is well worth it. Villina Grande Handover 10/9 Re: Things you forget - summary page 32 780May 28, 2014 12:15 am Pikey The Ebs I am building the ivy 4 with new living homes and have replaced the large open wall with a double cavity slider. A theatre room isn't a theatre room unless it can be blocked off We are doing the same. The room can also be a guest room if it has the ability to be closed off. We also added cavity doors to other areas of the house for heating and cooling efficiency. An open plan is nice but not always practical. My thoughts exactly on closing it off ! Sorry for the novice question, but what exactly do you mean by a 'cavity' slider. Does that mean the slider door recesses inside of the wall ? as in between 2 courses of brick Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11646 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8420 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6633 |
