Browse Forums Kitchen Appliances Re: Best brand/model of rangehood 900mm?? 12Nov 01, 2012 8:47 am Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Best brand/model of rangehood 900mm?? 14May 05, 2014 9:01 pm Building is both exciting and stressful Re: Best brand/model of rangehood 900mm?? 16May 13, 2014 3:24 pm I queried an schweigen approved installer over these two models: I have checked out the Harvey Norman exclusive (UM-900MS vs UM1170-9SP (1600m3)- "The three speed is fine, it has the same power on high as the five speed but you only have two other speed options instead of four" whereas the model you stated is HN-9UM. I'm only doing chinese stirfry, casserole type dishes with occasional pan fried. The installer and a sales rep advised me to go the 1600m3 as if you went the twin motor (1100m3), you have to cut two holes in your roof space whereas you will only need one for the 1600m3 and the 650m3 is pointless. http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Re: Best brand/model of rangehood 900mm?? 17May 15, 2014 2:53 pm Thank you boosta. Sorry I did not provide the model number of the rangehood that I was after more information. As you have found out is HU-9UM. Are both UM-900MS or UM1170-9SP available in the single motor 1600m3 version? Is there a big price difference? Building is both exciting and stressful Re: Best brand/model of rangehood 900mm?? 18May 16, 2014 12:10 pm happysarah Thank you boosta. Sorry I did not provide the model number of the rangehood that I was after more information. As you have found out is HU-9UM. Are both UM-900MS or UM1170-9SP available in the single motor 1600m3 version? Is there a big price difference? UM-900MS - http://www.harveynorman.com.au/schweige ... ehood.html - $1198 - I believe so, you might want to clarify with HN or schweigen. UM1170-9SP is the 1600m3 model and my builder quoted to supply only - $1827 (in lieu of builders std), it will be around that price at harvey norman or spartan electrical (got quoted $1860). Found my chat transcript with the schweigen sales: The UM-900MS is made from a lower grade of steel compared to the UM1170-9S. As you mentioned the UM-900MS only has 3 speeds. (11:47:56) Haley: The UM-900MS has aluminum filters where the UM1170-9S has mesh filters. (11:48:41) Haley: Basically, the UM-900MS is a cheaper version of the UM1170-9S with less functions (11:50:36) Visitor 70114650: I saw the UM1170-9SP (1600m3) at a showroom and I can not 'feel' or heard the exhaust from speeds 1 to 3. The sales rep told me to run it at speeds 4 to 5 during cooking. I asked if that will wear out the motor sooner and he said now. (11:50:42) Visitor 70114650: *No. (11:52:47) Haley: Yes that is correct. Speeds 4 and 5 are usually used during heavy cooking. Speeds 1 to 3 are used for basic style/ regular cooking. Cheers Clem http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Hi Chippy, no there isn't, gave it a really good look through and literally opened everything and checked all edges as well. Hence the question, just hoping someone would… 2 2170 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 12718 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 5991 |
