Browse Forums Heating, Cooling & Insulation Re: Hydronic Heating - Which Brand to Choose? 14Apr 30, 2014 11:09 pm Woops, just realised I forgot to ask what I came here for. Does anyone happen to know where I could download the manual for the Bosch thermostat? Model FR120 I think. Thanks in advance. Re: Hydronic Heating - Which Brand to Choose? 16May 04, 2014 7:31 pm Hope I'm not too late joining in. I haven't really got a brand preference but would stick with the specialty European brands ... we have a Baxie Luna. What i would totally insist on is a condensing boiler. Gas is about to go up in price along the same trajectory as electricity did... an condensing boiler will pay for itself in just a few winters Re: Hydronic Heating - Which Brand to Choose? 18May 05, 2014 3:01 pm Crazyk I've been thrown into a tail spin and can get an Immergas condensing boiler cheaper than the Bosch. I'll be going that way Can I ask how much the boiler is???? Re: Hydronic Heating - Which Brand to Choose? 20Jul 23, 2014 9:12 pm Thought I should add a few Hydronic things to look at before someone starts laying the cash:- Check the valves they are supplying, are they European (German are best IMO). Are they thermostatic? (This should be a yes for efficiency, except for the valve in the same room as the wall thermostat - this should be manual and always open). As for piping, I didn't use PEX, but I cannot see why Rehau and similar shouldn't be a problem. I would forget any installer who is using push fit or o-ring style PEX as the seals will eventually deteriorate (that's what seals do). Is the boiler appropriately sized for the installation? Almost all boilers in Oz used to be around 30kW and installers just install these and still mainly do. For a smaller install, a boiler will only modulate so much (down to around 20%). For example, my install was 6 radiators, (can't remember output), and a 30kW is too inefficient (too big) for this and I went for the 18kW Bosch unit. (UK sells 10, 12, 15kW etc, but we're stuck with boilers that have been tested to AU regs). I've had no problems with the Bosch unit since new (2 yrs old). However, don't buy the Bosch 'programmer', its junk, I bought it then sold it. Get a Siemens or Honeywell, much more logical and better functioning... Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4858 Anthony Firstly, wow you have put a lot of work into your list of questions! Great job and they are mostly valid questions that a builder should be able to answer. As… 14 10673 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4781 |
