Browse Forums General Discussion Re: solar electric 2Apr 25, 2014 4:16 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: solar electric 5Apr 26, 2014 9:18 am lovejones Yes i am in WA. yes the analogue dial does run in reverse if we are not using all the power, what is FiT? I am guessing the same applies throughout Australia, so am wondering if the power companies try and slog people, even if paperwork was mailed to them, when eventually getting the meter changed over. FiT = Feed in Tariff So whilst the dial runs in reverse, you are getting a FiT of whatever your peak tariff might happen to be. In these days of no or very low FiT's an old disk meter could be giving you a better deal than a new meter giving you minimal FiT. They can not back charge you what they think you might have used, so I wouldn't be worried about that. After all, you did send the paperwork in, and you really have to assume that it did get to them in the post (you can't be held to account if Aussie Snail lost them in transit). I've heard in another forum, that there was an inordinately high number of applications that supposedly never got through for unknown reasons. In your case, I'd be giving them a call once you have a contract on your house, and give them a rev up to get the new meter put on, and if they then tell you that they never got your paperwork, you can resend it through. You must remember that you have done nothing wrong, you sent off the original paperwork in good faith. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: solar electric 6Jun 25, 2014 6:30 am Ok I might post my question here. Didn't find much else on a search. I just scored myself 40 x 100ah 12v polymer gel Narda batteries. Not sure if I should set a system up with them or not or just put in a standard solar system. The problem I'll have is that the battery bank will be approx 40m from my DB board Re: solar electric 7Jun 25, 2014 11:40 am Once you get technical on solar you may be better trying the energy matters forum http://forums.energymatters.com.au/active-topics.html The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: solar electric 8Jun 25, 2014 12:43 pm Re HWS Booster. Put a temperature gauge (simple digital thermometer from ebay with an external probe) on your wall and only switch the booster on when you need hot water and the temperature is below 36. Mine takes less than half an hour to "top up" the hot water. The way a booster normally works, it will come on after you have used your hot water for showers etc and then keep it hot for the next 24 hours until you need it again....a great way to waste power. Re: solar electric 11Jun 28, 2014 8:11 pm Crazyk I can't even register on energy matters forum because I can't figure out their stupid anti bot questions. Why do they need to be so difficult The EM forum like many others, experience a lot of spammers registering and then spamming the forum full of their crap. Persist with it, if you're interested in solar it will be to your benefit. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6761 Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2835 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2664 |
