Browse Forums DIY, Home Maintenance & Repair Re: Correcting an old spakfilla job gone wrong... 2Apr 23, 2014 3:47 pm Couldn't you just sand it down? Build thread: viewtopic.php?f=31&t=65085 Re: Correcting an old spakfilla job gone wrong... 3Apr 23, 2014 5:46 pm EmyN Couldn't you just sand it down? That's a good idea. I had a look at it earlier though and it's a large area (about 40cm x 40cm) and I'm worried it will turn into an even bigger mess... I guess I could try and sand it down and if that fails I could just cut around it and back block a new piece of plaster board in there - unless anyone has any more ideas? Re: Correcting an old spakfilla job gone wrong... 4Apr 23, 2014 8:00 pm Depending what product they have used some don't sand very well, especially when there painted. If it does sand back take all the high spots off then put a skim coat over the top that you can sand flat. Feather it out a couple of hundred past the original patch and you'll never know its there. Unless you can't use a trowel and it looks the same as when you started but bigger. Re: Correcting an old spakfilla job gone wrong... 5May 21, 2014 2:05 pm Spakfilla on such a large whole is not ideal. when pressing the middle of the gap does it seem stable? Spakfilla is more suitable for small cracks or holes. I would personally place plaster in there with joining tape and use the appropriate joining compound. If suitable when pressing I'm sure sanding is fine. If you find its not durable, knock it out. Hope this helps! Re: Correcting an old spakfilla job gone wrong... 6Aug 14, 2014 7:54 pm Simply cut it out and start again. You will find it much easier to re -do than to try to rectify steve@everlastpatios.com.au www.everlastpatios.com.au Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7123 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10475 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 12548 |
