Browse Forums Safer Living Re: IP CCTV system recommendations 18Apr 22, 2014 10:09 pm Crazyk I have a heap of cat5e. Will that be good for future expansion? Does cat 6 just have an extra wire? Cat 5e will suffice. Cat 6, the sheathing is a bit thicker, more robust with it's inner 'spine' being thicker. And copper is a tad thicker I think. Using Tapatalk IP CCTV system recommendations 19Apr 27, 2014 12:59 am New Cat5e cables only read Cat5. If you have Cat5 that should be more than enough for CCTV cameras. But better to stick with descent quality HD cameras (Hikvision, as mentioned above) with good quality POE switch. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20651 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19517 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9793 |
