Browse Forums Kitchen Appliances Re: Ovens with Proofing Function 3Mar 21, 2014 2:52 pm It is the rising of dough. So having a proofing function on an oven would make the process faster, because at the moment baking things like cream buns, or anything else bread/yeast related takes HOURS. And yeah, I like baking, but faster is always better to me Re: Ovens with Proofing Function 4Mar 21, 2014 3:31 pm I know neff does in their 60cm range. All you really need is very low ambient stable heat. You could probably achieve this by using a tray at the very bottom and the proof the dough in the middle of the oven. It may work out cheaper to buy a used proofer if you have the space. Cheers Mark Re: Ovens with Proofing Function 5Mar 21, 2014 5:07 pm Well you learn something new every day! Good luck on your search. Build thread: viewtopic.php?f=31&t=65085 Re: Ovens with Proofing Function 6Mar 24, 2014 2:04 pm AussieMark I know neff does in their 60cm range. All you really need is very low ambient stable heat. You could probably achieve this by using a tray at the very bottom and the proof the dough in the middle of the oven. It may work out cheaper to buy a used proofer if you have the space. Cheers Mark Thanks Mark. Doesn't seem like anyone has it in a 90cm range. Dunno if I'd have the space for a proofer. I've also been hesitant to just try the oven on a low heat, but maybe it is worth a short, as I'm quite attached to the 90cm oven capacity. Re: Ovens with Proofing Function 8Mar 25, 2014 6:07 pm I like to use the v-Zug steamer to do my breads Isn't called proving ? Or is it the same thing Re: Ovens with Proofing Function 9Mar 26, 2014 2:24 pm I park my car in the driveway then put the dough in that to proove - works a charm! My new oven will have a defrost function (falcon 900 professional FX) Not sure if thats just the fan or a little heat too? Re: Ovens with Proofing Function 10Mar 27, 2014 10:00 am Staceyd I have a Falcon oven, hope you love yours as much as I love mine. I prove my doughs either on top of my coffee machine or turn the oven on to preheat and sit the bowl on top of the vents at the rear of the Falcon cooker. Some things are worth waiting for. Re: Ovens with Proofing Function 11Mar 27, 2014 10:39 am Great, thanks heaps everyone for the suggestions. I've done the trick of sitting it on top of the car before. & Sharon it is either proofing or proving. Take your pick. I agree with Althom but there also may be a problem with the terra cotta stormwater pipe discharging water in that areas as well. You can just see the top of the pipe at… 2 14895 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20618 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16177 |
