Browse Forums General Discussion Re: Linking 2 water tanks, why doesn't this work? 8Mar 11, 2014 4:18 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 12Mar 14, 2014 12:10 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 14Mar 15, 2014 12:59 am acem8 Does a reduction in pressure on the inlet side of the pump cause the pressure switch to kick in? A pressure drop on the (inlet) suction side signals that the tank's water level is low. This will make the pump stop; it is a run dry protection feature of pressure switches. A pressure drop at the discharge indicates a demand, for example, a tap opening. This makes the pump start. acem8 The main house pump is approximately 1/3 the height up the big tank. So do I fit a non-return valve at the inlet to both pumps? If a pump isn't flooded, it needs to have a check valve fitted. The cottage pump is flooded and would not normally need a check valve, however, the house pump is now drawing from the same line. Without seeing the plumbing, I can't give an accurate assessment but I earlier thought that a situation might exist where the house pump would draw against the cottage pump. Given that the cottage pump is 2 m below the small tank and that you have 32 mm pipe, this is now unlikely as the tank's head should generate a flow rate that would exceed any flow demands. The house pump is not flooded at the big tank's lower water depths and it needs to have a check valve fitted on a flooded section of pipe. This must be before the balance line for obvious reasons. Re low water levels in tanks, I posted earlier that the pump's draw valve on the tank must have at least 200 mm of head to prevent a vortex forming. Many pump manufacturers recommend a 300 mm head. The head is from the TOP of the pump's draw valve to the tank's water level. Naturally, vortex formation varies as it depends on the suction velocity and the size of the outlet valve and the pipe. There is a formula for this but it is complicated. I can post it if needed. Given that you are using the water inside the house, is this for potable use? If so, then the pump's draw valve should not be fitted close to the bottom of the tank to prevent it drawing the worst quality water from the anaerobic zone. If the TOP of the valve is let's say only 130 mm above the bottom of the tank, your minimum water level should be no lower than 330 mm. IF the valve was sitting at the very bottom of the tank, then your minimum water level would still be close to 250 mm but having the valve at the very bottom is unthinkable. Without being on site, it is very difficult to give an opinion as the need to know the levels and pipe lengths is critical. The description of gushing water flowing from the house pump indicates that there is no check valve. Is it a self priming pump? Fitting a check valve would be my first step. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 15Mar 15, 2014 10:16 am Blue Line poly pipe. The link below shows a chart with the Blue Line specifications. http://www.polypipe.com.au/images/PE%20 ... nsions.pdf The nominal pipe size is shown in the LH column. Go along the top column until you get to SDR 13.6. This is the same pipe as PN 12.5 (not shown). PN 12.5 indicates a maximum pressure rating of 1,250 kPa. If you align the SDR 13.6 with 32 mm, you will see that the 32 mm (OD) Blue Line poly pipe has a minimum wall thickness of 2.4 mm and a mean ID of 27 mm. SDR indicates the ratio between the wall thickness and the OD. In other words, a lower SDR indicates a thicker wall, a smaller ID and a higher pressure rating. For the lay person, the PN rating is less confusing but the use of the SDR rating is increasing. The two specifications are often listed together, see table in the link below. http://www.polypipe.com.au/prod46.htm The choice of the pipe with the most appropriate pressure rating must allow for valve and solenoid closures as well as pump start ups that all produce pressure waves. The difference between the internal volume of metric and rural poly pipe is substantial. A 32 mm ID pipe has a volume of .804 L/metre. A 27 mm ID pipe has a volume of .573 L/metre. As per above, a 32 mm ID pipe has 40% more volume than a 32 mm OD pipe with a 27 mm ID. The pipe's ID is always used when doing flow rate calculations; never ever use the nominal size. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 16Mar 19, 2014 4:01 pm SOLVED!! Well kind of, I'm still not completely sure what was happening and neither could the experienced guy at the plumbing merchant. I previously posted that I thought the balance pipe was empty because I could hear water coming through as I opened up the small tank ball valve (BV2). However, if I close off BV5 situated after the main house pump (in the pressurised pipework) then it doesn't happen. So somehow the 10m of head pressure in the house pipework was feeding back into the small tank. Fitting a simple non-return valve as shown in the diagram below has stopped that happening and now I am able to run off both tanks at the same time or one at a time. I have also concluded there must be a non-return valve buried somewhere between the big tank outlet and the point where the balance pipe intersects. This would also explain why I am unable to balance the tanks. Also the 3-4m of head pressure above the cottage pump means the main house pump does not draw on the cottage pump. The cottage pump cannot draw on the main house pump because I have now installed the non-return valve. Question - can I leave BV3 permanently open and the main house pump will take from whichever tank has the higher water level? All pipe diameter are the same, the main tank has a slightly easier flow path but then the small one isn't complicated. http://i122.photobucket.com/albums/o260/acem8/WaterTankSetupv3_zpsbc4d911b.jpg Re: Linking 2 water tanks, why doesn't this work? 17Mar 19, 2014 5:35 pm acem8 Fitting a simple non-return valve as shown in the diagram below has stopped that happening and now I am able to run off both tanks at the same time or one at a time. SaveH2O The house pump is not flooded at the big tank's lower water depths and it needs to have a check valve fitted on a flooded section of pipe. This must be before the balance line for obvious reasons. I would have fitted the non return valve before the balance line so that you can transfer water between tanks. As is, you can only transfer from the smaller tank to the larger tank PROVIDED that there isn't a check valve already fitted somewhere near the larger tank (as I believe there is) that is already stopping water flowing from the smaller tank to the larger tank. With the new check valve fitted in the balance line, you will not be able to use it as a balance line although the house pump will be able to use the balance line to access the smaller tank. acem8 Also the 3-4m of head pressure above the cottage pump means the main house pump does not draw on the cottage pump. The cottage pump cannot draw on the main house pump because I have now installed the non-return valve. Correct...but the cottage pump also cannot draw from the big tank due to the new check valve. acem8 Question - can I leave BV3 permanently open and the main house pump will take from whichever tank has the higher water level? All pipe diameter are the same, the main tank has a slightly easier flow path but then the small one isn't complicated. The above is assuming that there is an 'unknown' check valve near the large tank that is stopping water flowing from the small tank to the larger tank. BV3 is redundant for any purpose other than to isolate the smaller tank from the house tank. Most water will be drawn from the tank with the greater head relative to the house pump, particularly during low flow demand. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 18Mar 20, 2014 12:54 pm I choose to put the non-return valve in the current position because it was easy to do for test purposes - it just screwed in to the ball valve BV3. I could move it to where you suggest but I have 2 reservations; 1) The position suggested would be 400mm below soil level and behind a bush which makes access in the future difficult. Are these valves service items that can go wrong? 2) After major rain events the level in the big tank will be higher than the overflow in the small tank. If BV4 is not closed I could slowly lose water from the big tank? 3) If the big tank ran out of water and we closed BV4 and then ran both properties off the small tank, is there a possibility of creating an air lock in the system if the small tank water level was below the suggested position of the non-return valve? ie. cottage pump pulls all the water out of the balance line. Re: Linking 2 water tanks, why doesn't this work? 19Mar 20, 2014 4:46 pm It is only an educated guess when one cannot see the topography. Some things suggested are not always feasible. At the moment and assuming that there is a check valve near the large tank that prevents water being transferred into that tank, the current set up only prevents water from being transferred between tanks. While having a facility to transfer water would be handy, it probably matters little to your situation as it is something that you can get around if needed. The big tank should not lose water if the new check valve does its job. Nevertheless, you would be wise to close BV3 whenever the house pump is not drawing from the smaller tank. I was concentrating on air pockets and air flushing rates because of earlier advice that there was not another check valve fitted near the bigger tank. You will not get entrained air or air pockets unless a tank outlet draws a vortex at a low water level. The air has to be infused. Provided the tanks water levels are sufficient, this won't happen. The unknown check valve was preventing water draining back from the house pump to the big tank but when you fitted the balance line, you created an unrestricted flow path to the smaller tank. Depending on the height of the water in the smaller tank in relation to the height of the house pump, air could/would have been ingested into the house pump when the height of the house pump and the smaller tank's water level reached equilibrium. The pump noises would have been a result of the pump trying to run with some air in the pump. It is strange as to why the pressure switch did not stop the pump when it detected low pressure. There has to be another check valve already fitted near the big tank that prevents water flowing back from the house pump to the big tank. If there isn't, then water would have been flowing back prior to creating the new flow path to the smaller tank. There being another check valve is evidenced by the fact that you are unable to transfer water from the smaller tank to the bigger tank. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 20Mar 21, 2014 9:58 am Is the smaller tank's outlet valve that supplies the pump(s) a 32 mm valve or do you have a 32 mm (27 mm ID) poly pipe connected to a 1" or even a 3/4" outlet valve? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17361 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17871 |
