Browse Forums General Discussion Re: Ceiling Fans - are they easy to self install? 5Oct 08, 2008 12:46 am Fu Manchu we had a ceiling fan with a light in it in our bedroom in our last house. Installed way back before we got aircon in '98.( at least 2-3 years b4. We still used it when we just wanted air movement or when the night was very humid right up until our last summer in the house ( last xmas) ours never made a lot of noise. I think you lucked out. We certainly didn't have a vibrating glass problem at all. Re: Ceiling Fans - are they easy to self install? 6Oct 08, 2008 9:36 am I installed mine quite a while ago, so I'm not sure that I remeber all the numbers correctly but: the fan anchor point must support loads of 50kg min. The blades must above the certain level, depending on height of the ceiling. You can probably find this info somewhere. I saved on installation by making the anchors myself, then hanged up the fans and get the sparky just to wire them. As for the noise, go for quality, el cheapos are often noisy. Try http://www.hunterpacific.com.au/
Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Ceiling Fans - are they easy to self install? 7Oct 08, 2008 9:59 am So you cant just install a fan over one of your ceiling light? I was going to do that to my alfresco after handover. I didnt know you need a sparky to do it!
But the builders charge so much for the fans!! Re: Ceiling Fans - are they easy to self install? 8Oct 09, 2008 1:27 am wonderland But the builders charge so much for the fans!! Dont talk to the builder, talk to the sparky onsite and offer him some cash to do it while he is there and he may be able to do it and also clear it with the SS. Re: Ceiling Fans - are they easy to self install? 10Nov 21, 2008 11:42 pm Wait what the...Im lost..so is it good or bad to installl a fan by yourself???
We need one for the alfresco too...now it has one of those china hat thingy on the roof with a globe fitted but I thought it was just something like removing the globe and sticking the fan in.... Please... Re: Ceiling Fans - are they easy to self install? 11Nov 22, 2008 6:13 am sacha - should be done by a licenced electrician. After 4 years - we're in! Re: Ceiling Fans - are they easy to self install? 12Nov 24, 2008 2:37 pm You can install fans yourself, but as far as i know you have to already have a light in the spot u want the fan and u just replace it with the fan.
we did it ourself, my husband has done 3 now, replaced a light with a fan that has the light in the middle and they are good, no probs here at all. Re: Ceiling Fans - are they easy to self install? 14Nov 24, 2008 3:03 pm I wouldn't self install anything like this. I'd only ever used an electrician. It's illegal for anyone but an electriacian to install them anyway, isn't it?
And liability if something does go wrong is a whole other ball game..... I leave you to fend for yourself, figure things out yourself. Terrence Malick Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6686 DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41645 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 14442 |
