Browse Forums General Discussion 1 Feb 19, 2014 12:06 am Does anyone know if it viable to construct a basement garage in Class M (alluvial, silty clay) soils. There is rock approximately 4m below ground level, with class m soils above. I would imagine that it would not be cheap to excavation class m soils in comparison to class A (sandy soils). Re: Basement garage 2Feb 19, 2014 4:48 am There is No easy answer to your question about viability as excavation will be only part of the cost. As for the ease of excavation I would expect that it would be more expensive to excavate for a basement in sand than alluvial clay/silt. (Digging sand is slightly easier but support of the sides much more difficult) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. DIY, Home Maintenance & Repair to do it properly you need to dig out the garden and waterproof the outside of the wall. There are some products you can put on the face of the bricks but the water is… 2 4904 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17346 |
