Browse Forums Renovation + Home Improvement Re: En-suite/ Second Bathroom Configuration 10Jan 31, 2014 1:14 am I'd still remove the hallway door, surely if you need to use the bathroom you can walk two extra steps through nerd room? Or use old bathroom. Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: En-suite/ Second Bathroom Configuration 11Jan 31, 2014 5:49 am I agree leni. Then you can finish off the second bathroom/proposed ensuite as it will be and no need to block up the hallway door down the track when you make the office the master bedroom. Stewie Re: En-suite/ Second Bathroom Configuration 12Jan 31, 2014 8:41 am J54 A sliding door would be great, but I think I read somewhere on this forum that sliding doors werent allowed to wet areas anymore...? We have a sliding door into our ensuite, and the house is currently being built, so all good in Victoria at least. Re: En-suite/ Second Bathroom Configuration 13Jan 31, 2014 5:50 pm leni I'd still remove the hallway door, surely if you need to use the bathroom you can walk two extra steps through nerd room? Or use old bathroom. My husband works from home on the phone constantly so we wouldnt be able to go through that room for access during work hours, but I suppose its not the end of the world if the bathroom doesnt much use. We werent planning on blocking up the door when we used the room as a master though because we envisioned it used like a powder room guests could use instead of the kids bathroom/toilet (figured ours would be a lot cleaner than theirs!). ugbug We have a sliding door into our ensuite, and the house is currently being built, so all good in Victoria at least. I'm in WA but maybe its only some states So if we lose the second door, it would probably look like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: En-suite/ Second Bathroom Configuration 14Jan 31, 2014 6:55 pm Much better Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: En-suite/ Second Bathroom Configuration 15Feb 01, 2014 9:33 am I think that looks much better - especially the shower. Hi team, Im looking for a second hand sd4b monitor preferably white. 0 8923 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37144 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8478 |
