Browse Forums Building A New House Re: Henley williams landing melbourne 10Jan 29, 2014 12:47 pm there you go I didnt have time to look last night, but they were around $36 from memory When do you start building Melbournex Re: Henley williams landing melbourne 11Jan 29, 2014 3:59 pm That's fantastic, we will go with battens too instead of luxury pack. It would be close to $1200. This way we can upgrade to LEDs later on. Re: Henley williams landing melbourne 12Jan 29, 2014 4:07 pm Yea I will get the exact cost for you, as the luxury pack is quote expensive, when you can just get it all done after handover and if you get an electrician who is well priced you can get it done very cheaply!! Where are you located again?? Was it the south east?? Re: Henley williams landing melbourne 13Jan 29, 2014 4:16 pm I found a pretty descent sparky, but he was keen to do everything during construction time. I wasn't sure if Henley will allow him to do anything and can create more trouble for me. But changing battens to LEDs would be straightforward for him. I'm planning to use his services for ceiling fans, and drop lights. We are up north, craigieburn. Re: Henley williams landing melbourne 14Jan 29, 2014 6:06 pm Henley won't let you use your own contractors until after handover. Adding lights after handover is way cheaper than what they offer. You will most likely get a better light too. Approx cost installed for an LED light is $80-$100ea Re: Henley williams landing melbourne 15Jan 29, 2014 7:07 pm I had exact same concern that it won't work with Henley or any other volume builder. Same sparky told me that he can source LEDs for $14 each from somewhere. Re: Henley williams landing melbourne 17Jan 29, 2014 7:54 pm Crazyk Wow that's cheap. I would insist on good quality ones ie Phillips or something not a no name brand It was sounding like his trade secret. I didn't insist much at that time as he was more after wiring during construction stage. What should I look for when buying LEDs ? Brand, watts, angle, etc? 2 2959 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 12174 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 11887 |
