Hello,
I've only moved into my house around a month ago but with plenty of guests any a house warming party, most of my walls are stained, does anyone know how to remove these without altering or affecting the paint?
Thanks.
Browse Forums DIY, Home Maintenance & Repair Re: Stains on walls? 4Jan 19, 2014 8:24 am Handmarks - maybe just water and a rag ? Vomit etc ... after a while ... sugar soap ? You may need to paint over bad marks - after a wash - if you can't remove without damaging paint work. Re: Stains on walls? 5Jan 28, 2014 10:50 am Even hand marks will leave a brownish stain on walls.
If the stains have been put on the wall that has been painted with a flat paint then you are out of luck. Wherever you scrub you will probably leave another mark. If the walls have been painted with a low sheen or semi-gloss paint then the advice above should get rid of the worst. Stewie Re: Stains on walls? 6Feb 01, 2014 7:43 pm More than likely even if you do remove them you will leave big shiney patches on the wall that will stand out. Depending on the paint colour and how dark the stain is you may be able to re roll the wall straight over the stain. If the paint doesn't cover, use something like called stain stop. This will seal off the stain and you can then paint over the top. Re: Stains on walls? 7Feb 05, 2014 3:11 pm This link might help , how to remove stains from wall http://www.howtocleanstuff.net/how-to-c ... ted-walls/ Re: Stains on walls? 8Feb 06, 2014 8:25 am If I were you I'd try to dab the stain with some water and a rug first. Depending on how dark the marks are, it might work just fine. Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5449 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6057 |
