Browse Forums Lighting + Lighting Design Re: LED down light decisions 2Jan 12, 2014 4:51 pm Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: LED down light decisions 5Jan 12, 2014 8:57 pm The Wattsaver is a great light, and agree it may be very bright depending on how many you install. As discussed, I'd probably get a few to try in your rooms, and go from there. sometimes 2x you will find will be enough, so always good to check. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: LED down light decisions 7Jan 15, 2014 6:42 pm xxkatxx We bought the dl9-1200s in natural white with the diffused glass. We did quite well in guessing what we needed for each room, getting samples helped with this! Bedrooms 3m x 4m: used 3 Living/dining 5m x 10.5m: used 10, roughly 1.5m from the walls and 2m apart. So 2 strips Master bed 4.3m x 4.3m: used 4 Bathroom: 2m x 4m: used 3 (wanted it bright ) Theater 4m x 5m: used 4 I would certainly recommend them but only downside is that you can't just go and change a light bulb. ..gotta change the whole unit This is great info and helps everyone decide on the coverage that is attainable by these lights. Anyone else have significantly different setups? Re: LED down light decisions 8Jan 18, 2014 10:58 am This is great info and helps everyone decide on the coverage that is attainable by these lights. Anyone else have significantly different setups? Yes this is good advice, but remeber, everybody has different tastes and expectations of light in a room. Some people may prefer it to be brighter, and add a dimmer to reduce when needed, others may hate the brightness, and opt for less light. It all comes down to personal choice. The best thing thing to do would be to sample the room with a few lights before cutting any holes, and gauge it from there. You may find that 4 has a better coverage for you as opposed to 3. Hope this helps Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: LED down light decisions 9Jan 18, 2014 3:01 pm Thought I might add that in our alfresco (15m x 4m) we used 10 lights so same number as living/dining which is smaller. The spacing in alfresco is 3m long ways and 2m between the 2 rows. We need dimmers out there at night! Re: LED down light decisions 10Jan 18, 2014 9:59 pm Hi xxkatxx and delatite13 If is used the DL9 1200's in say a lounge room that's 3.5x4.0m would you recommend 4 lights or will 2 lifts be enought? Either set up will be on dimmers I just need to decide before the electrical plan is finalised. Re: LED down light decisions 11Jan 18, 2014 10:51 pm The DL91200 was not available when we got ours.(I wish it had been) Suffice to say we have a room 4.3 x 4.5 with one light with a standard dimmer. 2 would have been preferable - if your reading etc- but for tv etc quite simply too bright. The 1200 being slightly less I would use 2 with the wattsaver dimmer. They say it will dim down to 10% so really cannot go wrong. Standard dimmers just do not go down far enough. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: LED down light decisions 12Jan 19, 2014 12:15 am This is where personal preferences come in our bedrooms are 3x4 and have 3 and I wouldn't want to go less. I'd be happy to go up to 4 especially with dimmers installed. We didn't decide how many lights in each room until the house was almost finished and then got some samples to try out. We just put a junction box in each room which can take up to 6 lights I think? Is it an option to try samples out? Re: LED down light decisions 13Jan 19, 2014 9:48 am Wow xxkatxx you have 3 DL9's in a 3 x 4 room. That must be incredibly bright with all on full. Out of curiosity any idea how often you have them all turned up full. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: LED down light decisions 14Jan 19, 2014 11:00 am We haven't got any dimmers installed yet, probably only going to put in theater and alfresco but haven't got around to it just yet. They aren't overly bright? The only reason we went with 3 was because we were worried about dark spots in the room. We get a nice even light in all of our rooms but this could also be due to the diffused glass. I think they are spaced about 900mm off the walls and then in an even triangle over the important areas in each room. Re: LED down light decisions 15Jan 19, 2014 12:12 pm I agree guys, its all about personal preference at this point. Some peoples tastes are the total opposite to anothers who thinks 4x in a 4x4 meter room is good. My advice is, buy about 4x, and hold them up to the ceiling and see what you think. I now its primitive, but works, and could potentially save you a lot of money. Always remember a dimmer can be installed if you find its too bright Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: LED down light decisions 18Jan 22, 2014 9:10 am No problem at all. Let us know how you go. It would be good to know how many lights you install in your rooms. Cheers Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28585 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12316 |
