Browse Forums Lighting + Lighting Design Re: E27 light globe - I am confused 6Jan 08, 2014 2:20 pm Hi, E27 stands for Edison Screw and the 27 stands for the diameter. They come in a range of designs including LED, CFL and Halogen. Incandescent is now obsolete due to the high wattage and heat they create. Please don't hesitate to let us know if you have any further questions. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au Re: E27 light globe - I am confused 7Mar 19, 2014 3:34 pm Southies, If you are environmentally aware and have a social conscience, just be aware that CFL globes contain mercury. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: E27 light globe - I am confused 8Mar 22, 2014 7:50 am SaveH2O Southies, If you are environmentally aware and have a social conscience, just be aware that CFL globes contain mercury. Although you're correct, it is extremely low levels. So low, that they continue to make them. I would opt for LED also, but some people are budget concious, so the CFL is a good alternative. Kind Regards, Kristin Lighting Expert Phone -1300 798 220 Email - service@golights.com.au Website - http://www.golights.com.au If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8833 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 12381 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 18179 |
