Browse Forums Kitchen Corner Re: Pantries - What does and doesn't work? 3Dec 30, 2013 5:21 pm Nonna's Nest House set for completion November 2013 Re: Pantries - What does and doesn't work? 8Jan 05, 2014 3:07 pm Jazzyjess, I will ask about the fridge and the closed space when I go and see the kitchen place. I love the idea of the deep shelves for appliances and the slots for the trays, thanks grumblebum. Thanks for posting the photos of your pantry Kyton, I like that you can see everything clearly. I really appreciate the feedback, thanks so much Loving our new home, Upper Hunter NSW on 2.5 acres Re: Pantries - What does and doesn't work? 9Jan 05, 2014 3:34 pm We like our pantry. Is very similar to the plans you have. I will see if I can locate the pics. here they are, this is when we first moved in, everything is much fuller now. We have 2 big windows in our pantry so have contained everything to just one side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pantries - What does and doesn't work? 10Jan 05, 2014 4:27 pm Danette Jazzyjess, I will ask about the fridge and the closed space when I go and see the kitchen place. It appears you have a large space and not a lot of appliances so it might not be a problem at all. Danette I like that you can see everything clearly. So do I. Loving all the photos! Re: Pantries - What does and doesn't work? 11Jan 06, 2014 12:24 pm kyton Approx 6m x 1.8m here. Four shelves stretch along two sides - 2 top ones 30cm deep, 2 bottom ones 45cm deep. Everything is in open, baskets and glass containers help with organisation. Only the microwave and small vacuum are plugged in - all other appliances get taken out into kitchen for use. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm glad I found this post. This is pretty much exactly what I've imagined for the small pantry reno I want to do at my place when we move back in. At present our pantry is a simple cupboard with very little room (food and small stuff only) and we don't have enough under bench storage for appliances, pots, pans, etc. So we're going to eat into the front room which is under utilised by us. Re: Pantries - What does and doesn't work? 12Jan 06, 2014 3:04 pm Snagger I love my pantry. It runs the complete length behind my kitchen but is hidden - just looks like a normal door. I find I use all my appliances a lot more because I see them all the time as well as food doesn't expire because nothing is hidden away. Some things are worth waiting for. Re: Pantries - What does and doesn't work? 13Jan 06, 2014 10:35 pm kyton Snagger I love my pantry. It runs the complete length behind my kitchen but is hidden - just looks like a normal door. I find I use all my appliances a lot more because I see them all the time as well as food doesn't expire because nothing is hidden away. Thats good to hear. Thats what I'm hoping to achieve with our plans. Good to see the measurements on your shelf depths. Would you make either one deeper or shallow or are you happy with the way they are? Re: Pantries - What does and doesn't work? 14Jan 07, 2014 7:36 am Shelf depths are fine for us. The bottom two I made deeper to allow for appliance storage plus the microwave. It also allows for storage of things I only use once a year - like boxes of Christmas crockery and a Christmas tree - their boxes all slide neatly on the floor under the lowest shelf. Some things are worth waiting for. Re: Pantries - What does and doesn't work? 15Jan 07, 2014 11:11 am kyton Shelf depths are fine for us. The bottom two I made deeper to allow for appliance storage plus the microwave. It also allows for storage of things I only use once a year - like boxes of Christmas crockery and a Christmas tree - their boxes all slide neatly on the floor under the lowest shelf. That's a good idea, keeping the christmas tree in the pantry! At what heights are you shelves at? I'm guessing they'd be similar to me plans which have mine spaced at 400 apart. I've got a high ceiling so was just thinking we could always have an extra one up high that would be good for things like the christmas tree as well but a step ladder and my height would be needed to reach it. Re: Pantries - What does and doesn't work? 16Jan 09, 2014 10:15 am Danette To give you an idea of measurements these are the shelving plans. http://i1055.photobucket.com/albums/s507/grumblebum54/plan5.jpg These are the slots in use. http://i1055.photobucket.com/albums/s507/grumblebum54/PICT0013a.jpg Regards, Grumbles Re: Pantries - What does and doesn't work? 17Jan 10, 2014 8:27 pm Maggie Beer said "only have shelves one container deep". I like the idea of not losing things, but my pantry won't be big enough to do that and fit everything in. My current pantry cupboards are just under 300mm deep = two containers and that's narrow enough to keep under control. I used to have a fridge-depth pantry cupboard and unearthed many ancient items when we moved after 12 years, so won't be doing that again nor a corner pantry - my mother has one and it's not easy getting to the back corner. Thinking about building Rawson's Huntley 27 Re: Pantries - What does and doesn't work? 18Jan 16, 2014 7:16 am Can we expand this thread to reach-in pantries? Our plans are for what seems a pretty-good sized reach-in pantry, internal measurements of 1175mm wide x 650mm deep. Internal height is limited to 2100, so nothing should be too far out of reach. I've specified u-shaped shelves that get shallower as they go up so that the ceiling light is not blocked by the upper most shelf. The two bottom shelves are 250 deep on the sides, 350mm deep across the width. I picked dimensions mostly by shopping Ikea --for example, the floor under the bottom shelf will accomodate Hutten wine racks, and their storage container range will all fit in a single row on either the 250 or 150mm deep shelves. Do others think that will be practical? Currently my 'pantry' is a 750mm wide particle board wardrobe with shelves in the basement, so almost anything will be an improvement... Drat. Now realize that even though I don't plan to plug anything in in there, I should have added a power point in case I want some rechargeable kitchen gadget in the future. Chris On the threshold of retirement... and trying to check my assumptions at the door Re: Pantries - What does and doesn't work? 19Jan 16, 2014 8:34 am We just have a reach in pantry too but I like the shelving ideas mentioned. I also came across a good idea in a mag yesterday. A little hard to explain but I'll try - the pantry is beside the bench top and they have a folding door where they meet instead of a fixed panel, the bench top extends into the pantry where you can keep your toaster/kettle out of sight. The shelves above and below this alcove are accessed by the normal pantry door. If I remember I'll post up pic tonight. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Pantries - What does and doesn't work? 20Jan 16, 2014 10:56 am ChrisE I've specified u-shaped shelves that get shallower as they go up so that the ceiling light is not blocked by the upper most shelf. The two bottom shelves are 250 deep on the sides, 350mm deep across the width. I picked dimensions mostly by shopping Ikea --for example, the floor under the bottom shelf will accomodate Hutten wine racks, and their storage container range will all fit in a single row on either the 250 or 150mm deep shelves. Do others think that will be practical? Currently my 'pantry' is a 750mm wide particle board wardrobe with shelves in the basement, so almost anything will be an improvement... Drat. Now realize that even though I don't plan to plug anything in in there, I should have added a power point in case I want some rechargeable kitchen gadget in the future. My ideal pantry setup for a two door 1000-1200mm wide is, Fixed full depth shelf at bench height with full depth internal drawers below. 3/4 depth adjustable shelves above with stainless steel pantry racks screwed to the back of the doors from bench height up. I am not a fan of the U shaped shelves, they eventually sag and getting stuff from the back corners is next to impossible! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 11304 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5238 DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1933 |
