themax
Wow darrell81, GREAT BUY!!
good price hey.theres a guy in brisbane who has a shop that buys all the reject material from builders.
http://cgi.ebay.com.au/Door-Entrance-Pi ... 19c26b3b52 there loss our gain
Browse Forums What's New Re: Doors from Corinthian! 23Jan 02, 2014 8:21 am MR2 yeah, our Melbourne office sends a ridiculous amount of doors off to grays etc Hi, I'm a first time poster in this forum and in the process of trying to line up everything in preparation to start building in Feb (hopefully - all going well). You mention doors are sent off to Grays. Are these internal doors you are referring to, front Pivot doors or both? Re: Doors from Corinthian! 24Jan 02, 2014 9:06 am haha, what ends up at grays is generally only the product that is a custom size, build or faulty which we are not confident other customers will pickup within a reasonable amount of time.. you might be best having a look through ebay as well? last I checked much of what has been through grays and other sources ends up there. if it's a new build I would honestly suggest for items like pivot frames that you talk to your builder as these require special intergration (the Pivot obviously, is part of the frame) Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Doors from Corinthian! 25Feb 18, 2015 12:30 pm is pivot or hinge door better for long run? 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Doors from Corinthian! 26May 03, 2016 5:03 pm Hi, I am planning to have a bigger front door 1200w * 2340h. Will a hinge system be enough for this door or should I go for pivot system? What will be the price difference? Appreciate any help. Cheers, Re: Doors from Corinthian! 27May 03, 2016 6:34 pm RegVic Hi, I am planning to have a bigger front door 1200w * 2340h. Will a hinge system be enough for this door or should I go for pivot system? What will be the price difference? Appreciate any help. Cheers, You will need to go pivot as if u go hinged the door will be too heavy. Second Build, this time with Carlisle 2016, can't wait! Beckham: viewtopic.php?f=31&t=67280 Canterbury: viewtopic.php?f=31&t=81175 Re: Doors from Corinthian! 28May 04, 2016 11:12 am PEARZ RegVic Hi, I am planning to have a bigger front door 1200w * 2340h. Will a hinge system be enough for this door or should I go for pivot system? What will be the price difference? Appreciate any help. Cheers, You will need to go pivot as if u go hinged the door will be too heavy. Hi Pearz, Thank you for your response. Do you know what the cost difference will be? Cheers, Re: Doors from Corinthian! 29May 04, 2016 11:21 am Depends on type of doors but i have heard it ranges from $2000 - 3000 to upgrade. This is in vic. Second Build, this time with Carlisle 2016, can't wait! Beckham: viewtopic.php?f=31&t=67280 Canterbury: viewtopic.php?f=31&t=81175 Re: Doors from Corinthian! 30May 05, 2016 3:25 pm PEARZ Depends on type of doors but i have heard it ranges from $2000 - 3000 to upgrade. This is in vic. Thank you Pearz Re: Doors from Corinthian! 32Dec 01, 2016 2:15 pm Beazley77 We have a 1200 x 2340 door with five sets of big hinges and it's fine Does anyone else have their 1200 Corinthian door on hinges and not pivot and have had no problems and think it's easy to open still?? I got told we shouldn't so I'm now I'm really undecided. Re: Doors from Corinthian! 33Oct 10, 2017 2:04 pm Probably a bit late of a reply but we have our 1200 x 2340 door in 4 hinges and also fine. Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& we have a standard size and often we have a lot of variety to choose 0 3607 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5099 |
