Browse Forums Building A New House Re: LOOSE LAY KARNDEAN - update from old thread 142Sep 24, 2013 11:45 pm Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: LOOSE LAY KARNDEAN - update from old thread 150May 14, 2014 10:55 pm Just wanted to update this thread with my flooring experience. Polyflor looselay has just been laid. And so far - I LOVE IT! http://drysdaletheridge.blogspot.com.au/ Cant fault it yet. lets see if it stands upto everyday life Eden Brae Drysdale 27 | The Blog Re: LOOSE LAY KARNDEAN - underlay of some sort? 151Jun 02, 2014 7:50 pm Hi Michelle Help! I need to pick your brain please! We are building a new home at the moment. We want to put Karndean Looselay in the passage/kitchen/meals/dining area and carpet in the "theatre" and study. Problem is the carpet will be 14mm high once the underlay is installed. As you will know, the Looselay planks are 4.5mm thick. So now we have a height difference between carpet and the rest of the floor. Is there an underlay which we can buy to install UNDER the Looselay Planks to raise them to the height of the carpets? We don't want the expense of having plywood laid down under the Looselay... the area will be about 91sq m. What do other people do? Thanks for your help. Dreamline Re: LOOSE LAY KARNDEAN - update from old thread 152Jun 02, 2014 7:59 pm We have ultra plush underlay and very thick carpet against the Karndean planks (approx 3mm thinner than looselay) and yes there's quite a difference but it's a gentle slope with a soft plastic strip against it and doesn't cause stubbing of toes or anything. It's no problem at all. I just took a photo but don't have my photobucket account going anymore Re: LOOSE LAY KARNDEAN - update from old thread 153Jun 02, 2014 8:04 pm l love my karndean planks,you need to care for it in a similar way to real timber. Re: LOOSE LAY KARNDEAN - update from old thread 154Jun 03, 2014 11:18 pm Dream line is agree with serial. Looking at my floors where it meets the bedrooms I wouldn't say it's to noticeable. Are the areas where the 2 types meet large openings or just normal door ways ? Agree to care as though real wood. No dragging of furniture around. Teaching the kids to treat it with care etc too Eden Brae Drysdale 27 | The Blog Re: LOOSE LAY KARNDEAN - update from old thread 156Jun 04, 2014 10:02 pm Renski Dream line is agree with serial. Looking at my floors where it meets the bedrooms I wouldn't say it's to noticeable. Are the areas where the 2 types meet large openings or just normal door ways ? Agree to care as though real wood. No dragging of furniture around. Teaching the kids to treat it with care etc too Hi Renski Have you got the Looselay or the thinner Karndean? I was worried I would get a noticeable dip?!! The two doors leading into the Theatre are normal single doors, but the one leading into hubby's study is a double door .... I thought Karndean wouldn't scratch as easily as wood or be as "finicky" .. if you know what I mean ... and that I wouldn't have to worry about water as much (like in the kitchen) ... but thanks for the advice. Dreamline Re: LOOSE LAY KARNDEAN - update from old thread 157Jun 04, 2014 10:05 pm water yes l have them in all wet areas no problems and you don't have to sand them back Re: LOOSE LAY KARNDEAN - update from old thread 158Jun 04, 2014 10:06 pm Looselay might be easier to look then timber, but you can't sand looselay back and reseal. This floor is certainly not foolproof. If you're not careful it will scratch and look sad. We just had our vinyl planks stripped and resealed (kind of like timber but not haha) and it made no difference to the visibility of the scratches at all Re: LOOSE LAY KARNDEAN - update from old thread 159Jun 04, 2014 10:10 pm ment they are better imo because you don't have to sand them back like solid timber.sanding is a pain with dust even with a bag on sander ,then you need to stay off floor when you reseal.SB did Karndean not inform you about dogs (re scratches)l was told treat it like solid timber. Re: LOOSE LAY KARNDEAN - update from old thread 160Jun 05, 2014 10:33 am pattycake4 ment they are better imo because you don't have to sand them back like solid timber.sanding is a pain with dust even with a bag on sander ,then you need to stay off floor when you reseal.SB did Karndean not inform you about dogs (re scratches)l was told treat it like solid timber. I have a cat, but am hoping to get a dog in the future (hubby will have a raised eyebrow when he reads this ) - We are getting Country Oak, so hopefully scratches and marks won't be as visible because the floor is not too dark ... A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7640 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11118 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
