Browse Forums Building A New House Re: Brickwork Defect: Misaligned Mortar Joints - Advice Need 3Dec 26, 2013 7:12 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Brickwork Defect: Misaligned Mortar Joints - Advice Need 4Dec 26, 2013 10:06 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Brickwork Defect: Misaligned Mortar Joints - Advice Need 7Dec 27, 2013 4:12 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Brickwork Defect: Misaligned Mortar Joints - Advice Need 11Dec 27, 2013 10:10 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Brickwork Defect: Misaligned Mortar Joints - Advice Need 17Dec 28, 2013 1:42 pm Just getting back to square one The difference between common brick wall and face brick wall is the appearance. Therefore the most important part of face brick wall functionality is the appearance (durability and structural adequacy are given) You pay more for face bricks and more for skilled labour to lay face brick wall. Why should you not get good brickwork? It is not too much to expect skilled bricklayer to know haw to set out bricks and to care about the work. It is not too much to expect builder to have a quality system in place that will monitor workmanship at pre determined stages and correct if required before bad workmanship gets out of hand. Builders and tradies that get away with poor workmanship will just keep doing it. I agree with Casa2 that render has significant maintenance issues which will hit your pocket further down the line Whilst I agree that it is important to have good working relationship with the builder I don't agree with appeasement because that will just give signal that you are soft. That's just my opinion Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Brickwork Defect: Misaligned Mortar Joints - Advice Need 18Jan 08, 2014 8:31 pm building-expert Just getting back to square one The difference between common brick wall and face brick wall is the appearance. Therefore the most important part of face brick wall functionality is the appearance (durability and structural adequacy are given) You pay more for face bricks and more for skilled labour to lay face brick wall. Why should you not get good brickwork? It is not too much to expect skilled bricklayer to know haw to set out bricks and to care about the work. It is not too much to expect builder to have a quality system in place that will monitor workmanship at pre determined stages and correct if required before bad workmanship gets out of hand. Builders and tradies that get away with poor workmanship will just keep doing it. I agree with Casa2 that render has significant maintenance issues which will hit your pocket further down the line Whilst I agree that it is important to have good working relationship with the builder I don't agree with appeasement because that will just give signal that you are soft. That's just my opinion The builder has washed the bricks again and the mortar perpends in some places are not just misaligned but there are many sections throughout the double storey home with mortar perpends wider than 20mm. I've made up my mind that I am not letting this issue go lightly. In fact, thanks building-expert, I've just called your company and organised a building inspection for tomorrow. Thank you for agreeing to come out to have a look so quickly as I need to be prepared for a site meeting with the builder tomorrow afternoon to work out a "solution". Look forward to meeting you on site. Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11246 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5350 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10160 |
