Browse Forums Home Theatre & Automation Re: What class amp do I need? 7Dec 19, 2013 8:47 am Builder: Dennis Family Homes House: Hartley Facade: Provincial Suburb: Lyndhurst Moved in! http://cynash.blogspot.com Re: What class amp do I need? 9Dec 19, 2013 1:18 pm Id go with an amp. Mainly cos of running power to active speakers. Do you have one at the moment? Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: What class amp do I need? 10Dec 19, 2013 1:30 pm No that's what I'm trying to work out. What sort of amp would I need to connect the red wires in my roof to so I can connect ceiling speakers? This is the setup I'm after: TV to audio points in wall using RCA cable Audio points to amp via what the red cables in my ceiling are Amp to ceiling speakers. Amp would preferably go in ceiling or overhead of a wardrobe. Re: What class amp do I need? 11Dec 19, 2013 1:32 pm Re Amp - I'd go for something with more power than you currently need to run ALL speakers and gear. Make sure it has modern fittings etc. And pick a good - not necessarily the top - brand. Look about for specials but never compromise the end product - which is the sound. I've found the Sony Amp's OK. Are you planning to run the whole shebang from the outside ? Re: What class amp do I need? 12Dec 19, 2013 1:40 pm I'll be running two speakers (maybe extend to four eventually?) that are to be connected to the TV outside. I don't plan on hooking them up to anything other than the outside speakers. Can you show me an example of an amp that would be suitable? I still can't work out how the red cables in the roof connect to an amp of what they actually are? Re: What class amp do I need? 13Dec 19, 2013 1:54 pm Why not just go into a shop - eg Harvey's, etc - they have all the info. Don't buy cheap or second hand. Just ask questions at any shop you're in and you'll pick it up. Then buy from the one's you like the best. Price isn't everything - but most of them match up. They'll show you the gear and explain it to you there and then. Much better than trying to get the info on here IMO. You don't have to buy. Explain what you're after - and then go to a few shops. Even a few of the shops that sell only tech gear. They love talking about it. But don't be snowed into buying a "you-beaut" model you don't need. If its only 2 speakers you'd almost get by with a simple sound system. Re: What class amp do I need? 14Dec 19, 2013 2:36 pm ![]() Can you show me an example of an amp that would be suitable? I still can't work out how the red cables in the roof connect to an amp of what they actually are? The pair of red cables will be left speaker and right speaker. Each red cable will have a pair of wires to hook into your amp at the back. The amp will power/drive the speakers. Looks like since they're both red.. knowing which one is which will be part of the fun ![]() Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: What class amp do I need? 15Dec 19, 2013 3:26 pm My speakers were set up on a small shelf I'd made and attached to the walls. Brought the cables through ceiling and down wall (inside) then had a "plug". I then plugged the speakers into this. I could then remove them if necessary - ie they weren't hard wired. This was inside though. But no reason why it couldn't be done outside. I have a new system now - plugs not wire - but the old one that used a wire connection - you just pushed them into the appropriate slot. Odd if they are the same colour - but you just try them. I don’t think so as the floor area over 300 square meters then it is class 3…. 12 18640 The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 10551 ![]() You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 5348 |
