Browse Forums Home Theatre & Automation Re: Whats too small to be Home theater? 10Dec 16, 2013 5:50 pm This will create some constraints, like projector selection / placement. 4m is not much depth for the room. I have a 100 inch 16:9 screen and a room that is 4.3m deep. My Benq projector needs to be between 3.6m and 4.5m from the screen. If you are going for a projector and screen, just make sure you very carefully check the specs on projection distances and that this is compatible with your room dimensions. Worst case you could go for a short-throw projector, however I believe these are better suited for data applications. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Whats too small to be Home theater? 11Dec 17, 2013 6:43 am Check out the projector selection calculator at projector central. Link at http://www.projectorcentral.com/project ... or-pro.cfm Re: Whats too small to be Home theater? 12Dec 17, 2013 6:56 am Just checked out the Panasonic PT AE 8000 3d projector. At 3.7 Metre throw distance, 1.75x zoom (about 3/4) you will get a 110 inch diagonal screen, which is 2.4 meters across X 1.4 M high. I think a good size for that room. This is at 25 fl which is nice and bright. It's a good projector at a good price. LCD offers more versatile placement options than a lot of DLP projectors. At full zoom you would get about 130 inch 16:9 screen size. Re: Whats too small to be Home theater? 13Dec 28, 2013 1:38 pm The worst thing about a home theatre is having a pretty much square room. A lot of rooms should not be called home theatre, but media rooms instead. Nothing wrong with that in itself, as that's all many people want. In my case the new house we're about to build has a HT room of 5.9 x 4.4m, so well away from being square. Good luck with your project. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Whats too small to be Home theater? 14Dec 28, 2013 2:38 pm Yep there are some simple rules to stick by. Getting the dimensions right in the room is key. Mine is 6.15 X 5.03 x 3.26 and when the builder changed the ceiling height by a brick they had to put it back so that the dimensions were still good. Not the end of the world if its not but makes getting the room set right easier. Re: Whats too small to be Home theater? 15Dec 28, 2013 3:49 pm That's a nice tall room you have there... 3.26m high. Mine is only going to be 2.55 high. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Whats too small to be Home theater? 16Dec 28, 2013 4:05 pm Yep the strange thing is that I designed my house around the HT. The bottom floor is all 38 course. and the HT is double brick all around. Hopefully the fit out goes to plan and we have many enjoyable hours in there...... Re: Whats too small to be Home theater? 17Jan 21, 2014 2:25 pm It looks like majority of you guys are going with more of rectangular theater room. But yeah, the other layout of this particular design falls in place and may be more important to us at the moment. Being a first home buyer cannot go crazy with customizing this thing any further. So it is staying 4.1 by 4.1. As another poster said it may be better called as Media Room, I am happy to take that. Also may be Rumpus room. Considering this room is media and living, has anyone gone down that path? Can I see any pics? I am assuming that kind of rules out insulation/isolation. Re: Whats too small to be Home theater? 18Jan 21, 2014 2:50 pm Macmaz, regardless of what you do, you will still have a great deal of enjoyment if you call it HT or media room, and as you mentioned even a rumpus room. Whilst it won't allow you to do full insulation or isolation, furnishings you choose can make a difference to the feel of the room. Heavy drapes over the windows that can be drawn when watching a movie, or even left open can help with sound. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Whats too small to be Home theater? 19Apr 14, 2014 8:47 pm Dont get stressed about the size or the shape ... its what you do with it that matters! Well placed speakers with some soft furnishings, a 100" screen and a good projector and you will have a room that others will envy! Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2523 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8264 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5638 |
