Browse Forums Lighting + Lighting Design 1 Sep 25, 2013 10:54 am My Build thread --- https://forum.homeone.com.au/viewtopic.php?f=31&t=67313 Final Builders Interview - 18th Nov 13 Site Works - 11th Dec 13 Slab - 16th Dec 13 Frame - 7th Jan 14 Re: Need advice re junction boxes for kitchen lighting 2Sep 25, 2013 11:12 am Build thread: viewtopic.php?f=31&t=65085 Re: Need advice re junction boxes for kitchen lighting 5Sep 26, 2013 10:14 am Thank you so much for your advice guys. I think I need to have another chat with my builder. In the end it probably wont make a huge price difference either way as its only a few lights. My Build thread --- https://forum.homeone.com.au/viewtopic.php?f=31&t=67313 Final Builders Interview - 18th Nov 13 Site Works - 11th Dec 13 Slab - 16th Dec 13 Frame - 7th Jan 14 Re: Need advice re junction boxes for kitchen lighting 6Oct 21, 2013 8:51 pm MrsG EmyN I would be interested in any replies because this is very close to the number of lights and layout we plan for our kitchen. Only difference is we're having 4 downlights under the overhead cabinets as well to light the rear bench. My only thought is would it not be better to have a two way switch operate those lights? I'm not sure how the rest of your house is laid out, or what's "above" the kitchen but if you're coming from above wouldn't it be annoying to have to walk through to the end of the kitchen to turn the lights on? Hi guys, I think it would be easier to leave all your electrical needs as standard and then get an electrician in after handover to complete whatever you need - lights, cabling, switches etc. unless you are building double storey, then get them to install battens (or junction boxes - whatever is cheapest) so the cabling is already in the ceiling space and get him to change over to the lights you want. The electrican you use should be able to supply downlights etc. but you are probably better off getting your own pendants - although if you have a picture, they may be able to source for you. For anyone in Melb, I can provide details of a sparky who can do all this for you and reasonable pricing! His work quality was great too!! We have used him a few times. He provided all materials too including our pendants (could get them a bit cheaper than in stores) Cheers ! Hi Mrs G, Would you be able to PM me the details of the sparky you used? Thanks heaps! Indigo 22 Potters Grove, Officer, Vic Aug '13 - Signed PWC Oct '13 - Conditional Approval Dec '13 - Formal Approval Apr '14 - Land Settlement Jun '14 - Site Start Oct '14 - Keys Re: Need advice re junction boxes for kitchen lighting 7Dec 30, 2013 10:17 am As already mentioned, get the island lights on a separate switch, but only get one batten fixed in the position where you want one of the fittings needs to be mounted by your builders sparky. Once you have moved in, you will at least have one light there that you can put in a cheap cfl, and get your own sparky in to finish it off. When we do our build, we're going to have a whole lot of batten fittings in place to give us some lighting for when we move in, then slowly but surely get the stuff we like put in. The plan then is to buy a group of nice light fittings, and get the sparky in to do them in batches to save on sparky call out fees.... cheaper one callout with 6 things being done, than 6 callouts. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Need advice re junction boxes for kitchen lighting 9Apr 21, 2014 7:42 pm We went the junction box route and I am sure it included the switch - which also has the pantry light on it (which will be installed by the builder). We are having our lights installed after handover but before moving in - doing pretty much the same as you but I haven't decided how many downlights yet. We are getting the downlights that never change the globes (they last for minimum 7 years, about $80 each then you get an electrician to change them when they do finally go). They are supposed to be very energy efficient and never get hot so no risk of fire in the roof. Re: Need advice re junction boxes for kitchen lighting 10Apr 24, 2014 9:03 pm joyfulbuilder We went the junction box route and I am sure it included the switch - which also has the pantry light on it (which will be installed by the builder). We are having our lights installed after handover but before moving in - doing pretty much the same as you but I haven't decided how many downlights yet. We are getting the downlights that never change the globes (they last for minimum 7 years, about $80 each then you get an electrician to change them when they do finally go). They are supposed to be very energy efficient and never get hot so no risk of fire in the roof. Sounds good.... i am importing my own LED's from the UK. Have you obtained a quote from a sparky to install ? Re: Need advice re junction boxes for kitchen lighting 11Apr 24, 2014 9:09 pm I haven't looked at sparky quotes yet. These particular downlights plug into a power point - so the sparky will need to install power points coming out of the junction box? (that's what my previous sparky told me, but I am in a different area now and it is too far for him to come so I can't use him) Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15341 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28958 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8964 |
