Browse Forums General Discussion Re: Cdc 2Sep 04, 2013 8:38 am In NSW the two are separate. The DA whether through council or a certifier or other agency is so they can see whether your application meets all state federal and local guidelines for height , setbacks, footprint on your site etc. The CC is more for the structure itself and is where you need drawings from a structural engineer, builders Lic. No., builders insurance policy etc. The two can be lodged at the same time but most people tend to do the DA or CDC first. Stewie Re: Cdc 3Sep 04, 2013 9:32 am Shane-Kelly Hello can someone tell me when you get your complying and devolment certificate do you still have to get a construction certificate or is that what the cdc is A complying development certificate is usually obtained via private certifier. You can go through your local council, but the private certifier route is more popular (due to less involvment from council). Complying developments are State legislation rather than local council so the requirements are stricter and your site needs to be suitable for complying development (e.g. not bushfire prone, flood prone, environmentally sensitive, native wildlife habitat etc). DA (development application) is through council. They approve a concept based on merit and compliance with council requirements. CC (construction certificate) comes after DA and is where a private certifier or council approves the buildings compliance with DA conditions, BCA compliance and structural integrity etc. When getting a building approval, it will either be complying development (though usually only for small, simple projects) or DA/CC. DA/CC is more commonly used that CDC. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 5835 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 3836 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 11663 |
