Browse Forums Building A New House Re: Building house on rocky land 2Sep 03, 2013 10:12 am ttts862 Hi all, Will there be a lot of additional cost to remove / cut the rocks? I think so. I can't possibly tell you an accurate amount, but I'd imagine there would be 'thousands' of dollars cost in breaking up and removing rock, plus costs associated with dumping it. Additionally there are the rocks you can't see, which are even more costly due to difficulty to remove. Tens of thousands up to 100k Re: Building house on rocky land 3Sep 04, 2013 9:40 am I'm not in the same situation, but someone building with my builder encountered a big rock on their block, and it cost many thousands to remove, about 25k if my memory is right. An alternative could be a raised house rather than a house on a slab, it may be cheaper that way, but then the build itself could be more. 13 6721 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 2705 Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 358408 |
