Browse Forums Pools & Spas Re: Sealing Pavers - Pool 16Aug 19, 2013 12:53 am What about if you have chlorine pool and granite pavers around it. Do you need to seal it even though pavers are supposedly pre-sealed? Re: Sealing Pavers - Pool 17Aug 19, 2013 9:25 am Saint Mike Thanks. And - after - say 4-5 years - would I just do a clean off and apply more sealer ? One other question - I notice some slight "peeling" on top of a few pavers - ie like a slight amount is coming off. Is this normal - its quite solid under the thin layer that's peeling. I love the little fossils in some of them - but I gather many peole don't. After the 4-5 years yep, just clean and re-seal. Ensure you use the same product so as not to worry about any compatibility issues. As for your peeling I'm not to sure about this. Depending on the type of finish your sandstone is will depend if this is normal or not. Unfortunately my area of expertise is in sealers, not stone. Ask the place where you bought it from or a local stonemason, they may be able to shed some light for you. Re: Sealing Pavers - Pool 18Aug 19, 2013 9:27 am AubinGroveFan What about if you have chlorine pool and granite pavers around it. Do you need to seal it even though pavers are supposedly pre-sealed? Pre-sealed stone is a bit tricky. I have found that most stones that are presealed are done so with a very cheap sealer. One that generally doesn't last long. They pre-seal it for transportation and storage so as to ensure it can be cleaned down to look new again. I have found most of these sealers will not really give any sort of stain resistance. I would always recommend sealing once the product has been laid. Re: Sealing Pavers - Pool 19Aug 19, 2013 10:47 am miteq Saint Mike Thanks. And - after - say 4-5 years - would I just do a clean off and apply more sealer ? One other question - I notice some slight "peeling" on top of a few pavers - ie like a slight amount is coming off. Is this normal - its quite solid under the thin layer that's peeling. I love the little fossils in some of them - but I gather many peole don't. After the 4-5 years yep, just clean and re-seal. Ensure you use the same product so as not to worry about any compatibility issues. As for your peeling I'm not to sure about this. Depending on the type of finish your sandstone is will depend if this is normal or not. Unfortunately my area of expertise is in sealers, not stone. Ask the place where you bought it from or a local stonemason, they may be able to shed some light for you. Thankyou. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7372 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 6476 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 19684 |
