Browse Forums Kitchen Corner Re: Plumbing behind fridge - affect the depth? 27Jul 27, 2013 2:21 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Plumbing behind fridge - affect the depth? 32Jul 31, 2013 12:47 pm Thanks Grumblebum. Our kitchen is very similar. Judging by what another member PMd me and your responses here I think 10-15cm outside of the fridge space seems the norm considering the door depth and handles need to be outside the space. Logically then the more bulky the door and handles are the more it will stick out. Like others have said, I'm sure it will probably look a bit odd sticking out for the first few weeks (as our current fridge is small enough to fit well inside the space in both width and depth), but over time it will just become normal. I really appreciate those who took the time to reply. Second Time 'Round Re: Plumbing behind fridge - affect the depth? 33Jul 31, 2013 2:34 pm In grumblebums photo most plumbers would put the tap in the single door cabinet beside the drawers. Normally the carcass of the fridge sits level with the cabinets and only the thickness of the door protrudes. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Plumbing behind fridge - affect the depth? 34Aug 06, 2013 5:16 pm I had in my last place as per what a few of the guys mentioned here.. the tap was placed in the cupboard beside the fridge recess and plumbed through with a small hole. This will give you an idea. Perhaps see if you can get the tap moved slightly? Re: Plumbing behind fridge - affect the depth? 35Aug 13, 2013 11:05 pm On a totally unrelated note to the plumbing, reading this thread and going through our design, we're probably not going to have water to the fridge (we like the fridge / freezer pigeon-pair setup) but I've realised that as we're having a pantry next to the cavity, I'll put the power-points in there with a "desk-grommet" in the cupboard wall separating them ! Thanks guys, P_D http://www.4cabling.com.au/desk-grommet ... -2184.html http://www.jaycar.com.au/productView.asp?ID=HP1228 . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plumbing behind fridge - affect the depth? 37Aug 14, 2013 4:19 pm After reading this thread and getting all prepared for various options for our fridge water tap our builder said "oh we put all fridge water taps in a little alcove/niche in the wall behind the fridge space so it doesn't take up any space in the cavity". How nice is that?! Sensible builders?! Build thread: viewtopic.php?f=31&t=65085 Re: Plumbing behind fridge - affect the depth? 38Aug 14, 2013 4:36 pm EmyN .....in a little alcove/niche in the wall behind the fridge space so it doesn't take up any space in the cavity". How nice is that?! Sensible builders?! From reading this thread, yes nice, but possibly more sensible if it was (in a alcove / niche) in the cupboard next to the fridge ? P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Plumbing behind fridge - affect the depth? 39Aug 14, 2013 4:57 pm Haha PD do you like stirring?? Meh, I can live with having to move my fridge in the rare instance of a plumbing problem occuring. Build thread: viewtopic.php?f=31&t=65085 Re: Plumbing behind fridge - affect the depth? 40Aug 15, 2013 1:10 pm EmyN Haha PD do you like stirring?? Meh, I can live with having to move my fridge in the rare instance of a plumbing problem occuring. Oh sorry, Not stirring at all EmyN !! As I said, we're pigeon-pair people so it's not an issue for us, but I was thinking that with 200Kg of fridge and 50 kg of food and drinks inside, it's not something Mrs P_D would be able to move in a hurry if the water line let go when I wasn't home*. Cheers, P_D *Things like this ONLY seem to happen to Mrs P_D, and ONLY when I'm not home !! . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27345 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5459 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8245 |
