Browse Forums Kitchen Corner Re: Undermount front loader in kitchen? 2Jul 24, 2013 10:53 am Why cant you still have a tub in the laundry? I've got no issue with the washer in the kitchen, it's very english though. I would consider what your plans are for the property, sell it soon? Stay forever? People buying a house will notice the washer in the kitchen and may not like it, people wont notice the issue with the door until they've bought it and moved in. Re: Undermount front loader in kitchen? 3Jul 24, 2013 11:40 am We'd like to move out and rent it out for two years in about three years time. Ugh the laundry is really small. I can just fit the bosch 7kg front loader just inside the back door I think. Ideally I'd like to have it set up to accommodate either a front loader or top loader but either way the tub has to go. Here is a rough plan. It's not to scale with correct measurements because a)I'm on holiday and b) I'm a donkey when it comes to measurements and scale Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Currently I have one bench and if I want to put four dinner plates on the bench to serve dinner I have to move the coffee and sugar canister to the top of the fridge. I'm working with a very small space and extending is cost prohibitive, it won't make the room longer just deeper and I'd not add much value to the house. I'd rather work with the space I've got and maximise the use of it. Re: Undermount front loader in kitchen? 4Jul 24, 2013 11:50 am Could you consider swapping the washer and fridge around? You could swap the hinges on the fridge door to better accomodate the opening door. You'll also be less likely to accidently open the door when the fridge is open (assuming there's some kind of window in the door) Tough space, ill think some more Re: Undermount front loader in kitchen? 5Jul 24, 2013 11:54 am Swapping the fridge and washer around would be best solution to be able to accommodate both front load or top load. I'm doubtful the depth next to the back door will take a top loader. I'm looking at about 75cm from the door frame to the wall depth wise I think. The fridge has to be side by side. I could put a freezer in the garage but don't want to risk power issues (busy bodies unplugging cords) The pantry can be custom width and depth. ta. Re: Undermount front loader in kitchen? 6Jul 24, 2013 1:49 pm can you change the back door so it opens the other way in, and wont hit the open front loader door? if you are going to have the washer in the kitchen, make sure it is concealed behind cabinetry so you cant tell. Re: Undermount front loader in kitchen? 7Jul 24, 2013 6:02 pm kiwi can you change the back door so it opens the other way in, and wont hit the open front loader door? if you are going to have the washer in the kitchen, make sure it is concealed behind cabinetry so you cant tell. Sounds like a good idea! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Undermount front loader in kitchen? 8Jul 24, 2013 8:43 pm kiwi can you change the back door so it opens the other way in, and wont hit the open front loader door? if you are going to have the washer in the kitchen, make sure it is concealed behind cabinetry so you cant tell. You can get the Asko integrated washing machine, it's designed to be integrated behind a cupboard door without increasing the depth. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7790 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9318 |
